#26 | |
Re: 88 3500 dually 4x4
Reducing the chamber volume to help bump compression & better cam timing numbers will definitely help. The exhaust flow benefits from headers helps too (air-in; air out). I did the above & switched to flat top pistons @ the same time.
#27 |
Not to steal the thread, but Scoti did you have to flash the chip?
#28 | |
http://www.compperformancegroupstore...MARKIVCAMHFTCC
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-04-2011 at 12:55 AM. |
#29 |
the adjustable pressure regulater helps also putting in new injectors step up and put an msd 6al box on with a hotter coil
as far as flashing your ecm it will help even if you dont do any engine mods find some one thats reputable in your area so he can hook up his computer to your truck and drive it around you'll get the best results I found my guy by going around to street rod shops and talking with guys that have computer controled engines in their rods and it seemed every one was using the same guy
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#30 | |
#31 |
Can't go wrong with the Edelbrock Performer matched packages, imo.
If you figure out how to run 35s on a dually let me know. I was under the impression it was the 3rd letter of the vin that identifies cab & chassis. I was just told a B is C&C. That axle does look a tiny bit forward, but it's normal with a lift. If it were a cab & chassis (regular cab) the axle would be back, not forward. 4 inches back.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
#33 |
just subscribing, i have a 454 tbi and am looking for a combination that i can just pickup and put on
#34 |
things have been moving along slowly on my truck but i have addressed some issues with the rear lift and removed the running boards and such got new tires and am rewireing the whole truck right now. The wiring had been cut up and had some pretty bad burnt spots in it so it is getting a whole painless wiring kit in it right now.
#35 |
i still need to address some other issues but i have been gathering parts in prep to doing a motor and tranny swap. I have a older 454 with better heads that i am going to put in it. it also has the edlbrock tbi intake on it. I am also having a 700r4 built for it but i am keeping the 205 transfer case.
#36 |
to run 35's on these trucks you just have to have lift and wheel spacers for the rear.
#37 |
Are you using factory 6" wide wheels? What is the size of your rubbers. I understand they are 35" but other dimensions. What size wheel spacer are you runnin?
#38 |
i am running 315 75 16 with a 2.5 inch spacer
#39 |
oh and yes i am running the factory width wheels. I have done this on several duallys over the years and had no problems.
#40 |
well had a little luck today. I had a set of factory 05 ford superduty wheels from another project that a friend needed and he had a set of american racing dually wheels so we did a little trading.
#41 |
6>8 Plugless........
![]() Join Date: Sep 2007
Those are nice wheels, but IDK how nice they'll look on your square man.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#42 |
Resident of Here
Personally I'd stick with the steel wheels or alcoa style wheels and take 2" out of the lift. PERFECT.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#43 |
good to see that eagle,globe and anchor on a truck.ooorah
#44 |
Love the tires on that truck, looks seriously mean. Tell me more about running that size tire, I didn't think you could do it on the stock rims.
I'm on my second lifted dually, and I hate that the tire choices are so limited. I have seen people run real wide tires on the skinny wheels, but I dont know that I'd dare. I mean, I've seen 36/12.50s done before. I had 255/85s on my 97 dually with a 1.5 spacer, no problems at all, but one tire shop wouldn't mount them because their book said no larger than 245. Situation I'm in now, I've got 6 inches of lift and can clear plenty, but I've got a cab & chassis with a fleetside bed over it. With 235/85 tires they stick out a tiny bit in the back. I just don't know how much more I could fit on there before I ran out of room on the inside, but I especially don't want the tires sticking way out. If I have to put flares on, that ruins the tucked underneath effect somewhat, plus the fronts might look funny because they won't need fender flares. I've been tempted to swap it to a srw, just so I can run some 35-37 inch tires. Honestly I'd be happy with 33s I think. Those pictures of the rear tires looks just like my 97 did, I always ran mud tires and it was a mean looking bunch of tread back there. Any chance you could get a measurement from outer sidewall to inner, so I could estimate where they'd be on my truck?
