#26 |
Re: Valve Covers
what i have on mine is- one side is pvc valve going to the vacuum source at the carb. the other side has a filler cap and then another with a check valve (i think- its not a pcv valve)and hose going to the air cleaner.
#27 | ||
"I ain't nobody, dork."
Re: Valve Covers
I needed a PCV on mine, and didn't wanna run it to the air cleaner. I needed full vacuum to my power brake booster, and I used the fitting in the back of my Holley 3310 for that. So I drilled and tapped a 1/4" NPT hole into my 1" aluminum carb spacer and ran a PCV hose from a fitting I screwed into the back of the 1" spacer over to a PCV on the valve cover on the passenger side.
I run a regular breather on the drivers side that pops out to fill engine with oil as well. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#28 | |
Parts and more parts
Re: Valve Covers
Many years ago Chevrolet used to have a vent setup on their intake manifold, instead of on the valve cover and the oil fill tube had a vented breather cap to let air in. That was back in the early 60s and late 50s era. Many of the Corvette engines of that time was set up that way. It did not last long, though. Attached is the last engine that I put in my 84 and it has the hose to the air cleaner and the PCV to the carb front
Frank Last edited by piecesparts; 07-02-2010 at 05:41 PM. |
#29 | |
![]() Join Date: Aug 2001
Re: Valve Covers
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#30 |
Re: Valve Covers
Shucks, fella---you all didn't have to fall onto the sword YET. We could have had some fun with this.
Frank |
#31 |
Re: Valve Covers
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
#32 |
Re: Valve Covers
Heres a picture of a 396 i built.. Notice the valve covers?? The second oneis a 4.3 that i'm building with an alum. Intake-carburated fuel del. System & hei. Definatly low-tech. (i just spent the last 20 minutes trying to get this d@mn little dig. Camera my son sent me.. Used with no instructions & i'm definately technilogically challendged)
#33 |
Re: Valve Covers
I've got to say that I have no clue which way is OK now. I think what I'm hearing is that you MUST have a PCV running to the carb, but a breather in addition to that is optional?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#34 |
Re: Valve Covers
that's why i suggest the easy way of doing things// you read the service manual once and it's in black and white with pictures and gives you the proper way that a PVC system is designed to work efficently
#35 | |
Re: Valve Covers
I have seen guys connect only a PCV valve and not vent the other side in some form, their intake becomes a muddled mess of oil and slime. If you pull on the crankcase and not provide air, then you will pull gasses past the piston rings and possibly could make your crankcase atmosphere vaporize more oil due to the negative pressure.
Frank |
#36 |
Re: Valve Covers
