Old 07-08-2010, 08:59 AM   #26
Shyguy
Junior Member
Shyguy's Avatar
Re: cooling suggestions?
Jegs and Summit both carry add on fans. I think I got mine from Jegs, but it has been quite a few years ago.
You also may find the right fan at a salvage yard.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-08-2010, 12:21 PM   #27
Bad70sbchevy
Bad70sbchevy's Avatar
Also sometimes they carry them at the local part stores. I think pepboys or discount auto carrys them.
Bad70sbchevy is offline   Reply With Quote
Old 07-08-2010, 03:20 PM   #28
lt704
Hi longhornMan, I have read alot about your cooling information. I have a 1968 C-10 with a 350 engine. It had a mechanicle cluth fan plus two electric fan set up with a on/off swithch, The set up had no shroud for the mechanicle fan. i disconeccted the cluth fan and run the electrical fans. I still have a problem with the gauge getting hot sometimes?. Would it improve if i put the clutch fan back on? Should i put a shroud on to, Should i use a 4x4 shroud being that my engine isfather back away from the fan?. Also my transmission cooler is right next to my radiator, should i put spacers between the radiator and transmission cooler? I know it's a lot of questions but i need the help. Thanks everyone...Russ
lt704 is offline   Reply With Quote
