Old 01-20-2011, 02:24 PM   #26
Puglia10
Re: Frustrated! trying to get bushings out of control arms
pics for reference what im talking about, sorry...
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 01-20-2011, 04:06 PM   #27
tubbedII
needs more $$$
tubbedII's Avatar
Yes, the part that's crushed is the steering stop. Most of the bagged guys chop the whole thing off and smooth it down. I just did it to my arms this weekend when mocking up my bags.
The issues are that you losing the bump stop should only be an issue if you're going to rub either the LCA on the ground or the tire in the wheel well during a bump. I haven't heard of anything with the steering stop removed. I turned mine lock-to-lock with the wheels on and didn't notice anything rubbing, but it was just sitting still in the garage.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-20-2011, 04:49 PM   #28
Puglia10
Hmmm, I'm not sure what I should do. I have a guy that will weld something up for me Wednesday, and Wed only, so I need to figure it out by then. I dont want to cut them off it'll make problems but I'm not sure what to make to fix it or serve the same purpose. Any ideas? Has anyone ever done this, I cant be the only one with crushed ones!? Thanks!
1979 c30 3+3 dually
1946 GMC
Old 01-20-2011, 06:00 PM   #29
jimmydean
jimmydean's Avatar
Gone.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-20-2011, 07:35 PM   #30
CheyenneShop
CheyenneShop's Avatar
Jimmy Dean - those look pretty! Did you just do those?
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 01-21-2011, 02:18 AM   #31
Puglia10
But then what? Do you run no bumpstops or fab up something? What do you recommend for a static dropped truck? and the steering stop?
1979 c30 3+3 dually
1946 GMC
Old 01-21-2011, 02:07 PM   #32
jimmydean
jimmydean's Avatar
I didn't have a steering stop on my '69 and won't on my '66. I will be running '77 control arms (pictured) with the Dropmember crossmeber.
<edit> I drilled out the spot welds (careful not to drill through to the arm) then knocked them off with a hammer. A few minutes with a grinder and wire wheel and you see the results.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-21-2011, 02:10 PM   #33
jimmydean
jimmydean's Avatar
Here's what it looked like after about 20 more minutes with the wheel.
They will look great when I'm all done.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-22-2011, 02:52 PM   #34
CheyenneShop
I am assuming with air bags?
72 3/4 long 4X4
69 SWB "Prospector"
Old 01-22-2011, 03:46 PM   #35
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Puglia10 View Post
...... I dont want to cut them off it'll make problems but I'm not sure what to make to fix it or serve the same purpose. Any ideas? Has anyone ever done this, I cant be the only one with crushed ones!?
Mine weren't crushed, but they were in the way. I wanted to add a stop that would allow me to roll when aired out. This is what RPL Customs built for me.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
