Re: I think I found a truck for me, please give your opinions.(PICS)
i wouldnt do it....it a 76,not one of ours period.....looks like alot of trouble to me.....keep looking
Still plays with trucks
I just noticed how close the transfer case shifter is to the seat.
If it is an NP205 you couldn't get that thing into 4 HI to save your life.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
VA72C10
![]() Join Date: Mar 2008
also, on any of these you look at, look on the roof, and inside above the windshield around and under the sunvisors for bubbles...this is a spot they rust out and is more difficult to repair....
and always check the cab mounts...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: Nov 2004
I am not a fan of primered trucks (for sale, I think they do look cool in primer) or "put together" trucks. Double whammy... walk away.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Did anybody else notice that it has a parking brake pedal and not the pull handle that a 68 would have? Pass on this one
Insert Title Here
He said the cab was a 72
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
I am a Referee of life.
You said it has "some" bondo.My some and his may be different and primer can cover a multitude of sins.If you don't do bodywork then it could get expensive quick.I think I would be very careful or just pass on this one completely.It might make a good bomb around truck or OR rig but for your use I think i would try to start with more of what you want.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 07-11-2010 at 08:57 AM. |
He had to have cut the frame or the wheels would be out of alignment with the wheel well openings as a 67-72 SWB is 115" wheel base and a 73-87 is 117.5".
2-1/2" would be really obvious. Look to see if the wheels are centered under the wheel well arch. If they are then the frame was cut and shortened. You can easily modify the location of the back of cab frame arch to put it in the right spot to work with a 67-72 cab while you are correcting the wheel base. It will allow you to mount the bed with only 3/16" steel shims under the bed rails rather than having to run a 3" body lift to correct for the mismatched frame curves. I am half way through this same project on my 67. I got the bed mounted yesterday and I should be building the new cab mounts today.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E Last edited by 68 TT; 07-11-2010 at 10:41 AM. |
It is missing rear shocks and one of the front bump stops is broken off. I hope he wasn't driving it around like that.
Insert Title Here
you can get away with out shortening the frame on a lifted 4x4.... 2 1/2" is a lot, but you can move the cab and bed forward or back and center it up close enough.....didnt even notice the no shocks...lol
Its a decent truck to fix a few things and drive, but if your plan is to tear down and rebuild, I would just start with another truck.... if your going to do all that anyway, might as well just get a clean truck 2wd or not and do a frame swap yourself
I've done the 67 -72 body onto 70's 4wd swap. You end up with the appearance of the body lift because of the difference in the frames. That's also why the front bumper looks the way it does. I'd also say the cab is just a tad too far forward, hence the bend in the steering rod. The mirrors are angled because they are off 73 & up ( I have a beater with a set just like them!)
I'd say this was a "left over parts" build - red dash & arm rests, blue seat, 68 title, 72 cab, 69 -70 front clip. I'd want to "meet the feller that done it" or see evidence of good work. But, several things would be warning signs to me - the broken stops & no rear shocks mentioned before, I noticed no e brake cable to the pass rear. I'd say this is not any where close to a 4k truck. IF it runs exceptionally well, drives nice, has good tires, is solid body wise - especially underneath & in roof, and has other desirable qualities, I'd say $2500 or less maybe - but I'll bet he's too proud of it for that. On this one you'd better feel like you stole it, because there's some things that need attention. |
#12 | |
Mine will appear much more like a stock 4x4 rather than a square body frame swap.
