07-21-2010, 10:06 AM | #26 |
Under Construction
Re: let's talk radiators
Pips, entropy uses dual spal fans, i think i would go with his setup. you can get the dual fan setup with the wiring for the price of the spals listed on your link above for just the shroud. I have several inquiries into Tony @ entropy, here is one of his replies:
The radiator and wiring harness with the dual fan setup are $649 ($549 for radiator with the dual fan setup and $99 for the harness). The fan/shroud combo is $249. If you buy the radiator and wiring harness together from my website (www.entropyrad.com) rather than Ebay, you can use the coupon DIRECT25 at checkout and take $25 off the total. Tony - entropytec
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-21-2010, 11:19 AM | #27 | |
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
07-21-2010, 11:35 AM | #28 |
Under Construction
no problem, let us know what direction you go.
07-21-2010, 12:22 PM | #29 |
im running a factory radiator from a 90's GM truck, uses original bigblock mounts and stock big block location on top with factory big block mounts. works just fine
07-21-2010, 12:33 PM | #30 |
I used this dual fan:
http://www.summitracing.com/parts/DER-16927/ with this dual fan controller: http://www.summitracing.com/parts/DER-16789/ I did have to make my own fan mounting brackets using angle aluminum. |
07-22-2010, 06:46 PM | #31 |
I got my shipping notification from UPS which said the radiator I bought from e-bay is coming from Entropy Corporation. The one I purchased from e-bay is from engineered cooling products? Dont know what is up but I sent a message to the seller to see if the radiator being sent is the same as Entropy on e-bay or entropyrad.com. Maybe they ran out and drop shipped an Entropy radiator to me. I saw they are both from Chicago area. If it in fact an Entropy then I will order his fan set up also.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 Last edited by PipsC10; 07-22-2010 at 07:10 PM. |
07-26-2010, 09:57 PM | #32 |
radiator showed up today. Not happy with the way it came. I'm contacting the seller to return the radiator. This will probably cost me unless UPS eats the shipping. The seller also charges a 20% restocking fee. Let me know what you guys think? The core also appears to have a bow in it. Looks like I will be saving a little more and going with a be cool radiator. I guess the saying you get what you pay for rings true.
07-26-2010, 10:42 PM | #33 |
The damage to the fins looks like unfortunate shipping damage or a lack of attention during packaging. I would be interested in a picture of the bow in the core. The only damage to the radiator I received was due to my clumsiness during installation. I believe you should send a quick email to the seller and see what they say. I will bet you get a quick turn around and a positive reply since the sellers ebay feedback is quite good.
07-27-2010, 12:19 AM | #34 | |
07-27-2010, 07:21 AM | #35 |
Under Construction
let us know if it's infact a entropy radiator or not.....
07-27-2010, 08:00 AM | #36 |
Not only does that not affect form, fit, or function, but after you put it in, no one could ever even see it.
I bet they'll send you a new one, and pay for everything in order to save thier reputation. Since they'll be sending you another one, or giving you money back, I'd drop it in the truck, and make sure the brackets and stuff fit; because it would suck to get a replacement just to find that it didn't fit in the first place. I bought one once brefore and everything looked great until I tried to screw my radiator cap on and it would not go on because it barely hit the radiator bracket. Had to cut the spout off and relocate it. |
07-28-2010, 11:17 AM | #37 | |
07-28-2010, 11:18 AM | #38 |
It is not an entropy, but the seller says he stocks their fan units so Im still not sure of the connection between the two.
07-28-2010, 11:45 AM | #39 |
07-28-2010, 01:31 PM | #40 |
You could probably straighten out the fins with a small screw driver or a pick, but if it has a bow in the core and you don't mind waiting, by all means wait for the new one. |
07-28-2010, 05:58 PM | #41 |
the seller just offered an exchange for an entropy unit with dual fans, paying for the difference of course. Not sure if he will waive the shipping since I have to pay to ship this one back. Waiting to hear back from him.
07-28-2010, 06:40 PM | #42 |
You should not have to pay to ship the damaged one back. It's their fault or the shipper's fault, not yours.
07-28-2010, 07:07 PM | #43 |
true, Im hopefull he will waive the shipping on the new one or pay for this one to be shipped back.
07-30-2010, 11:45 PM | #44 |
he is going to waive the shipping for the new unit. Entropy radiator with dual fans and wiring harness. Hopefully it shows up new! Have to wait for the one I shipped back to arrive before he sends the new unit out.
08-09-2010, 09:21 AM | #45 |
Under Construction
so did you just have to pay for the fans? and the guy is shipping you a entropy radiator for the same $$ you spent on the original radiator?
08-09-2010, 01:35 PM | #46 |
no, the original I bought was not an entropy radiator. I had to pay the difference between the original one I bought and the entropy unit with fans. He waived the shipping on the new unit. I also bought the wiring harness. Basically I had to pay shipping twice if you consider I had pay for the original shipping and to ship the old one back.
08-09-2010, 02:55 PM | #47 |
Under Construction
I emailed Tony, and he said they (entropy) offer the engineered cooling products as an alternate for budget minded individuals. let us know how you like it when you receive it.
08-10-2010, 12:04 AM | #48 |
Junk Yartist
subscribing
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
08-10-2010, 11:26 AM | #49 |
Thanks for looking in to it for me, that makes perfect sense now. A gentlemen named Mike has been in contact with me and I should get it late this week or early next week. I hope to add some more input for installation of this radiator and how it performs. I wont have it running until winter, but I know people wanted a true review of how this radiator works in our trucks. I anticipate that it will work great based on the reviews for other types of vehicles that have used entropy radiators.
08-10-2010, 01:52 PM | #50 |
"Trucks with Class"
I like Old Air's dual fan setup. It is designed exactly to bolt into 67-72 GM trucks, so it costs a little more...but, it is almost plug & play. Comes with all harness, relays and a great tech line from the guys who know their parts.
We can't buy a good copper OEM style radiator around here any more. It's all plastic and alum and u-g-l-y! |
