#26 |
*** That's interesting ***
Re: Motor Oil in Vaccum line from Carb to Distributor? Need help to stop this
Put a hand-held vacuum pump on the dizzy nipple and see if it holds vacuum. Perhaps it will actually pull some oil through. Won't that tell you if there's a leak in the dizzy? I'm also curious about the tee in that vacuum line...
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#27 |
TNT-MOTORSPORTS
What he said.......!!!!!! That is were I would start at also .
#28 |
I didnt see the t in the line at first, good eye, that would be my first guess. If that line is connected to the pcv I could see oil being pulled into the line from the vacum created by the carb, I would also think either your valve is stuck open or the vacum is holding it open cause the pcv should be releasing vapors no pure oil like your finding in your line. I would also venture to say that you are getting poor performance from your carb and vac advance due to the disruption of the vacum by that oil. Run one solid line from your carb to your dizzy and one solid line from your pcv to the correct inlet on your carb, and check you pcv to make sure it operates freely
#29 |
"THE GREEN GOBLIN"
Yes Iam running a PCV valve on the Driver side Valve cover and a breather on passenger side valve cover.. Yes you are correct there is a "T" in the line it is ls hooked up to my transmission modulator Th400.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#30 |
With the T to trans mod your distributor is not getting the proper vac signal and is not advancing correctly. As stated above the dist needs it's own line.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
