#26 |
More of the same.
![]() ![]() ![]() ![]() Let me know if you need more or an actual measurement for something. Good luck. I did need to massage the seem lip in the tranny tunnel to get more clearance for the vent tube on top of tranny, to avoid rubbing noises later. I like where mine sets. Plenty of room up front. Room behind. Not touching firewall etc. I did have to drill rivets out to move tranny crossmember forward, I think about 2 inches. The oil pan( truck pan) clears the front crossmember with at least a 1/4 inch or more. It hangs below frame though. Mines c20 at stock height, so who cares. Skid pan to come later though. The only problems I had with going this far back were the seem on tunnel needed folded back a little, the Lokar cable for shifter to me is a little short, tight bends. And my Doug Thorley headers dumped right in front of Parking brake cables, so it was tight bends coming out to exhaust. I thank my exhaust man for doing such a good job at that fix. Drive shaft needed shortened, but that fixed my vibration problems. Found out shaft yoke wasn't welded on square from factory I guess. Any questions just ask. Good luck. I'll take some pics of the plates I made for the motor mounts tommorrow. Last edited by usmcchevy; 06-21-2011 at 09:54 AM. Reason: clean up |
#27 |
Damage Inc
Re: LS swappers, post up your pics!!
heres mine
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
#28 |
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by leddzepp; 04-20-2014 at 04:10 PM. Reason: spam |
#29 |
![]() Join Date: Apr 2005
Mine....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-31-2010 at 06:39 AM. |
#30 |
here's a some what current one...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list
#31 |
The rims are eagle alloy 225's with toyp proxy II.
That is a factory 3 piece escalade covers that have been smoothed by driveway dreams(Gerald) and painted ![]() thanks for the compliments guys ![]()
#32 |
Moderator
![]() Join Date: Jul 2006
In progress. The block will be blue like the wheels and it will have cast aluminum finned valve covers. That is an NP833 o/d 4-speed behind it. Just finished putting in a 212/218 .522/.529 cam, LS6 springs, and TSP pushrods. Gonna need some less expensive tires for burnouts...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#33 |
Next project: 1970 K10
low_84_inchaska - I built a simple box mount for mine that sets up against the rad support, and uses two of the three rad support-to-inner fender mounting holes.
It's since been painted.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#34 |
5.3L and mockup transmission are finally mounted!
Here's the mounts we created. The chassis is 2003 S10, and the engine sits back about 8.5": ![]() ![]() ![]() What it looks like when attached to the frame (using all existing threaded holes and stock S10 motor mounts) ![]() Finally! ![]() I have a re-worked harness, LS1 intake, fuel rails, injectors, and idler pulley relocation bracket. I have an un-tuned PCM. I bought a F-body oil pan and dipstick tube. I bought F-body manifolds (which aren't going to work either). I still need all of the truck accessories and brackets. Also still need a starter. Also, I still need to cross my fingers, and hope that when we swap oil pans and check the bearings that everything looks ok. I still need an electric fan. I still need a 4L60E transmission (have a lead on one for $50, but needs rebuilt, will probably purchase soon). I assume that I'm going to need a MAF. Also need an air intake tube and filter. This swap will nickle and dime you to death. Don't go into the swap thinking you're going to spend less than $1500. It's just not going to happen. If anybody switched to a F-body or Vette accessory system, and still has the truck accessory drive that they want to sell, please send me a PM. It's going to suck forking out the money for custom headers, but we don't see any way around it. We may try to make our own though... Our next step is mounting the S10 steering column. Last edited by shaunatk; 09-27-2010 at 01:36 PM. |
#35 |
Boosted Member
5.3L / 72 mm turbo / head studs / rod bolts / LS6 cam / 4L80E and Yank 3400
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#36 |
Here is my LQ4 that will be going in my 85 4X4 burb. Has F body headers and SDPC Hot Truck Series HT1 cam 214/218 555/562lift and 111 LSA. Streat avenger 670 cfm carb and edelbrock duel plain intake. Awaiting fianl clean and assembly and paint.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#37 |
Here's what I got. 01 5.3l, 4l60e classic Performance tubular engine mounts, Sanderson headers.
![]() ![]() ![]() Check it out! I Just Started a Build thread |
#38 |
LS1 on K5 and LS1 on 74 C10
#39 |
67 short step LQ9 TH400 |
#40 |
Truck and auto performance nut
mines getting close....
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 08-12-2012 at 02:23 PM. |
#41 |
Got motor mostly back together and only have few more things to order.....we have all said that befor....
#42 |
![]() Join Date: Aug 2010
Here's mine. 2008 Silverado 5.3L / 4L60E in a 67 C10.
67 5.3L Build |
#43 |
Got a few more things installed...
#44 |
69' Chevy Stepside
![]() Join Date: Mar 2008
My 1969 Chevy C-10 Stepside Swap, started off as a simple 5.3L swap with a nice electroic 4L60E. Then I decided that wasn't good enough so I cammed it, that was a great improvement but then I decided to go crazy and swap it out with a completely build up LQ9 6.0L with brand new high flowing L92 cylinder heads, LS3 Intake manifold, 90mm throttle body, Comp Cams 223/231, .610/.617, on 112 lsa. I topped the new motor off with GM Performance Part LSX polished valve covers and hiding the coils in the frame rails!!!
![]() PICS: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() VIDEO: Many more pics in my build thread and I'm planning on taking it out to the track this spring to see how fast it is!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#45 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 11-29-2010 at 08:07 PM. |
#46 |
i finally explored this sight farther than the 60-66 section heres mine so far 1966 suburban 6.2 and a 6l90e porterbuilt front and rear
#47 |
Doesn't look all that great yet, but had the first start up last night!! That's my brother that sounds like a crazy person laughing, he was a little excited.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 |
#48 |
[attach]676327[
#49 |
[attach]676332[/attach
#50 |
im using duel electric fans kit from old air products ,had it on the truck when i had the 402 in it.thought i would go alittle modern with the 5.3 ,4l6e
| Bookmarks |
