#26 |
Re: traded a pellet rifle for a 350 today
Any ridge in the top of the cylinder? If not, a simple dingle hone and some new rings will be fine.
Was there any info stamped on the nose of the cam? |
#27 |
Well, just went out to check again, and there is a slight ridge. Figured as soon as I was able to see the cam nose, the numbers would be right there. Actually the nose looks rough (made like that I reckon) has a CC (one C stagerd over the top of the other C) and a 2 * 8 H (real rough where the middle number should be) Other numbers on the rear but can't make out all. Like 12 210 and 6698 across the bottom.
#28 |
Hmm. Didn't think about the ridge the other day. Better to bore it .040 if there is any ridge at all? (think I know the answer)
#29 | |
Or...if you screw it back together and it squeezes decent compression, leave it be. As for the cam...."CC"? Crane Cams? 2*8?....268, 288..those were grinds for chevys. Under the Crane Blazer series they had the 288H. Crane H268 206*/206* @.050 268/268* adv. 112LSA, .448/.448 lift rpm range 1500-4000 Crane Blazer H288 226*/234*@.050 288/296adv 114LSA .458/.473 (1.5 rocker) (this is technically a Pontiac grind, still looking for chevy numbers.) Most info on an H288 Crane cam points to a solid lifter cam. I'd be willing to bet you have a 268. |
#30 |
it is a comp cam high energy 268. the 12-210 is the part #. if you need a good machinist in nashville pm me and i will give you a # to a very good one.
#31 |
![]() Join Date: Sep 2000
Code Year CID Vehicle HP RPO Trans Carb Comments
CMR 74 350 Chevelle 145 L-65 T-H 400 2-Brl CMR 78 350 Corvette 220 L-82 TH 350 4-Brl CMR 80 305 Impala 155 LG-4 TH 350 4-Brl This may help
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
#32 |
Way clean on the inside with blue head gasket material---not original---must have been a refresh at some time.
The RWS pellet guns are great--got any more--I have a 350---010. in the barn just hankering to trade for a RWS??? hehehehe |
#33 |
Was the only one I had Huck. Deff. was rebuilt, and bored .030 over. Was just surprized at how clean it was inside, considering it was FILTHY on the outside.
#34 |
Grandpa in the rustmobile...
wonder if my filthy late 70's motor looks like this..probably not LOL
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
