Old 07-25-2016, 04:16 PM   #1
HO455
HO455's Avatar
Question Re: Lift gate supports
I too am interested in long term reports on this conversion. I would pass on it if they turn out like the ones on my S10 Blazer that go bad every 18 months. The WMB will be my daily driver and the hatch will see plenty of use. Thanks in advance for any input.
RIP Bob Parks.
Old 07-30-2016, 02:38 PM   #2
72MARIO
72MARIO's Avatar
I did this conversion a year or two ago. They were very hard at first to close they seam better this year. Either way they are much safer than the original design.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-31-2016, 03:52 PM   #3
HO455
HO455's Avatar
Thanks for the update.
RIP Bob Parks.
Old 08-03-2016, 07:43 AM   #4
zach_carver
zach_carver's Avatar
We just installed the ones from mcmaster website and the ball studs included did not work in our factory holes. We had to acquire the ball studs from gas pedal mounts. However we got them and still wish we could find some struts a little longer. Ours are the 20.12" long extended and 50lbs a piece lift the gate perfectly. We also installed the tailgate straps but they weren't long enough to let the tailgate open all the way. Any reasolution? We got the straps from ebay for 1968-91 suburban straps.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 08-31-2016, 03:33 PM   #5
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Here's a link to the McMaster PN I used. Can't believe I waited as long as I did for this retrofit. Works perfectly and no issue to date.
Originally Posted by BK72BURB_3/4Ton4x4 View Post
My OE hatch hinges never worked right so I've been using a 2X4 to keep the door from dropping on my head. Finally sourced some gas struts from McMaster: http://www.mcmaster.com/#gas-struts/=10gvykk and now the hatch stays up by itself!
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 08-31-2016, 09:25 PM   #6
notchbackgta
Link doesn't work, can you list the part number?
notchbackgta is offline   Reply With Quote
Old 09-01-2016, 12:20 AM   #7
BK72BURB_3/4Ton4x4
Smile Re: Lift gate supports
Click that little blue arrow to the right of BK72Burb_3/4Ton4x4 in the quote two posts up and it will take you to the original post
Old 09-01-2016, 11:02 PM   #8
notchbackgta
In case anyone was wondering.... 4138T585, the last 5 is for the 50lb versions
