07-25-2010, 09:59 PM | #26 |
Grandpa in the rustmobile...
Re: Whats the procedure for cutting front springs..
Cool keep us updated! Is he gonna try to run a trac bar or make one?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-31-2010, 01:34 PM | #27 |
Chevy Lover Till The End.
I'm not sure. I was suppose to go up and visit him today in my '69 but it's raining. I may drive something else and head up anyway. I will let you know. Ted
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
05-26-2011, 05:57 PM | #28 |
Instead of cutting one coil from the bottom, would it be better to cut half a coil from the top and half a coil from the bottom?
'69 Fleet It ain't yours, if you didn't build it! |
05-26-2011, 09:29 PM | #29 | |
67-72 parts collector,…
The bottom (only) can be cut. The top has a smaller pigtail end that fits up in the crossmember, and matches up to a "D" shaped piece of steel. When you have the spring out,... look up in the spring pocket and you will see it.
05-26-2011, 11:11 PM | #30 |
I chopped the coils on my impala and iwas told to put the cut ends up top.Big mistake!One side worked its way up into a little opening in the frame and that side wouldnt move.I had to take it apart took me about two days to pull that spring out of there.
05-26-2011, 11:41 PM | #31 |
Happy to be here
Just an FYI for anyone considering cutting a coil spring. There are several ways to cut them, and as mentioned always avoid excessive heat. I have used many of the methods mentioned. One that wasn't mentioned is a "tile" blade in a circular saw. A tile blade is essentially a thin abrasive disc like those used in a cut-off tool. This is larger and made with the correct style arbor so it fits properly in a circular saw. If you don't have anything else to do the job, that old Black and Decker or Skill saw will work just fine.
05-27-2011, 06:21 AM | #32 |
It's alsways something.....
I used a cut-off wheel in my 4 1/2" side grinder to cut mine. (brand name--METABO 'original slicer' is the deal!) Here is a photo for reference, it has 1/2 coil removed and 2 1/2" drop spindle. 5" drop springs on the rear.
I did this suspension mod during the build and then it went to the alignment shop, had it aligned, all was good...
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e Last edited by chuckmc8; 05-27-2011 at 10:53 AM. |
05-27-2011, 07:43 AM | #33 |
lolife99 speaks truth.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
05-27-2011, 10:17 PM | #34 |
05-29-2011, 09:57 PM | #35 |
Leave that stance alone..Geez..it does look good the way it is. Go swimming already so you wont hack the poor thing anymore than it is! J/K!!!!!
Tags |
goose is loose |
