Old 02-14-2011, 07:08 PM   #26
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Engine mount adapter options
Glock, Just wanted to say thank you for taking the time to do this write up. I ended up with the 6 cyl stands in the rear position and modified my 1" set back plates to be like your #3 plates on both sides.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-16-2011, 01:47 PM   #27
67Dad
We are putting a 93 SBC 5.7 in a 67 c10. Current plan is to bolt engine straight to bell housing and tranny (muncie granny low 4 spd) leaving drive train intact, (engine a little further back that original v8 position.)
Do any of you know which engine mount(s) styles/adapters we'll need?
Thanks.
Mark
Mark
57 Austin Healey 3000 (sold many moons ago, unfortunately)
67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition
93 C4 Corvette (mostly done, son's)
67Dad is offline   Reply With Quote
Old 02-16-2011, 03:23 PM   #28
usmcchevy
usmcchevy's Avatar
Thanks.
Mark
A 93 5.7 is not a LS so it should bolt right in, no adapters needed.
Build thread
LSx Swap FAQ index
Old 02-16-2011, 03:40 PM   #29
67Dad
With standard 292 cid mounts (or 250 cid)...the C10 had a 250 in it when we got it and originally had a 292 according to the glovebox label? (I think someone told me the 2 are different).
Thanks again.
Mark
(Or is there another standard mount (ie 350cid ones) that will bolt up straight to the frame?)
Mark
Old 02-25-2011, 11:46 AM   #30
sdwolff98
Turning Wrenches Daily
yeah the 292 mounts are different one is the same and the driver side is the 6 cyl mount that mounts in the back set of holes ont he crossmember.
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 11-04-2011, 04:50 AM   #31
79shortbed
79shortbed's Avatar
This is somewhat related; I have Solidworks 2011, and have designed my own plates based on the #2 plates shown by glock. If anyone would like some designed differently, PM me how far forward/back you would like the motor to sit with a few dimensions, and I can drawn/design them up and see if I can send them to you in a pdf or something. I just need to know which way the SBC holes need to move compared to the LS holes to move it forwards or backwards. I did mine in 1/4" steel, but can change the material to anything from steel, aluminum, pvc, plastic, carbon fiber, whatever. I'll see if I can figure out how to post some pics from Solidworks, or if I even can. Being in Mechanical Engineering has its perks
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 11-20-2012, 10:52 PM   #32
Auctioneerhere
That is awesome!
Auctioneerhere is offline   Reply With Quote
Old 12-16-2012, 03:04 PM   #33
cjohnson6772
cjohnson6772's Avatar
I thought some of y'all might like to see how I notched my a/c bracket to work with the plates that move the engine forward 1 1/4". I'm putting the POL stands in the 6 cyl holes which moves the engine back about 2 5/8" so in total my engine should move back about 1 3/8".
cjohnson6772 is offline   Reply With Quote
Old 12-16-2012, 03:28 PM   #34
hilljob26
hilljob26's Avatar
great info,,,
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 01-16-2013, 04:28 AM   #35
birdistheword
birdistheword's Avatar
Does anyone know who makes an engine cross member/mount for the LS engines for the 67-72 4x4 trucks other than Pacific Fab? Cause I really don't want to pay $400 for their's.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 01-16-2013, 10:11 AM   #36
jstplyn331
jstplyn331's Avatar
Here is what I used, I agree with you on the price. This kit is great and price you have room for fabrication
http://www.classicperform.com/Store/...cks/4810LS.htm
You can see it in my build thread
Build Thread,
jstplyn331 is offline   Reply With Quote
Old 01-17-2013, 12:19 AM   #37
birdistheword
Thanks for the info. I might go that way then.
Erik
Old 01-23-2013, 10:40 PM   #38
SchreinerM
All the adapter plate options noted use the original motor mounts. Has anyone used the LS mounts?
SchreinerM is offline   Reply With Quote
Old 01-30-2013, 12:12 PM   #39
mcbassin
Still Learning
mcbassin's Avatar
Check this out: HERE
mcbassin is offline   Reply With Quote
Old 01-30-2013, 02:49 PM   #40
JJH Jimmy
JJH Jimmy's Avatar
I didn't like the price of the Pacific fab one either and i didn't think that it look very good so i built my own. I used schedule 80 seamless pipe and fittings buffed the welds down flush then blasted and painted it. I probably don't have more than $50.00 in it including the poly bushings. Here are some pictures. If you want some pictures of it installed let me know.
JJH Jimmy is offline   Reply With Quote
Old 04-20-2014, 03:29 PM   #41
ztk123
I just pulled the BBC/TH400 out of my 71 2wd blazer. I have purchased a 5.3 4l60 for my swap. The center line of my existing bbc mounts and tail shaft measure out to be within a 1/4" of the center line of the ls mount and tail shaft. It looks as if everything would line up pretty well. I was wondering if it is possible to use adapter plates with my BBC mounts for the install or if I should should change them out to SBC? Any advice or insight is greatly appreciated!
Thanks,
Mike
ztk123 is offline   Reply With Quote
Old 05-18-2014, 07:11 AM   #42
47 Fasttoys
47 Fasttoys's Avatar
OK, my mount/cross member situation is a little different then most but I will share it just the same. I modified the original mounts and attached them to a 2X2 cross member. This is bolted to the outside of the frame for drop-down engine removal. Using the F-body pan the 2X2 sits with it's bottom edge 1/4" below the pan. Of course this system isn't gonna work for front engine mount, but for mid engine it's the ticket.
Exhaust clearance issues?....hahaha! I laugh at exhaust clearance issues.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 06-27-2014, 12:26 AM   #43
Junkpyl
Lots of good info here but my head is kinda swimming with a bunch of unsure. I have a 68 C30 that I'm going to be converting to a C10 and it doesn't have any motor mounts, towers, or engine. I have a 2002 5.3 and 4l60 to go in it. My question is, what mount would be the easiest on the wallet and ease of installation since I am starting from scratch with no original hardware? Thanks in advance for any support.
Junkpyl is offline   Reply With Quote
Old 07-02-2014, 12:15 PM   #44
Matt Cramer
If you're not using the truck A/C compressor location, a set of adapter plates that put the bellhousing in the stock location and a set of stock smallblock mounts / stands would be my first choice. Using the '73 and later stands / mounts will give a bit more exhaust clearance.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 01-18-2015, 01:23 PM   #45
Marty68
are these 6 cyl mounts? back wards? i have 01 4.8 going into 68. was originally 6cyl. but had 305 in it. would like to put it as close to where 305 was as possible. to maintain driveshaft length.
Marty68 is offline   Reply With Quote
