Old 10-06-2010, 07:54 PM   #26
Tchia65
Re: 58 Fleetside
I've made a little bit of progress lately. Not nearly as much as I'd like. Building it not at home with limited access is really becoming a pain. All the front end welding is done and got it painted. Motor mounts are built around the rack and pinion and to put the drivetrain at 3*. Steering column is a gutted 67 Caddy with gear shift and ignition removed and the case smoothed, made it's mount and adapted a 63 Rivera wheel to it. The wheels so big though I don't need it to telescope anymore. In process of making my rear step notch, and waiting to paint the firewall so the motor can go back in.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 10-13-2010, 01:22 AM   #27
Tchia65
Re: 58 Fleetside
Painting on a military base in California is a *****, but finally got the fire wall done. Plus they are only open 4 days a week. Should have the front end back together and motor in by this time next week. Then get started on the back.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-13-2010, 01:45 AM   #28
hotrod1
56 - autocross
hotrod1's Avatar
Re: 58 Fleetside
Nice work!
hotrod1 is offline   Reply With Quote
Old 10-13-2010, 02:00 AM   #29
Tchia65
Re: 58 Fleetside
Originally Posted by hotrod1 View Post
Nice work!
Thanks, you too. I see you went the No limit route too. How was the back to install. I hoping to get my rear in this month.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-13-2010, 10:29 AM   #30
hotrod1
56 - autocross
hotrod1's Avatar
Re: 58 Fleetside
We dont really have the 4 link done yet. We are not too comfortable welding it all in place (other than tack weld) it in until we can make sure about centering it in the wheel wells. I have been told that the axle centerline is 36" from the back of the frame. I hope that this is true as we already c notched it. Are you going to c notch yours? We are waiting for a rear end still to mock it all up.
Old 10-13-2010, 07:25 PM   #31
Tchia65
Re: 58 Fleetside
I still have the stock rear end installed so I'll let you know if it's 36" or not. I'm bagging my truck so I built a step notch instead. I took the easy route and picked up a 3:73 posi explorer rear end for mine.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-13-2010, 07:49 PM   #32
hotrod1
56 - autocross
hotrod1's Avatar
Re: 58 Fleetside
Tell me more about the rear end? 9 inch? It is limited slip? What is the width from mounting surface to mounting surface? I am looking for 60". If I could go with a explorer rear that fits, I would do it. I am sure it would be a lot cheaper than going with a built up one.
Old 10-13-2010, 09:59 PM   #33
Tchia65
Re: 58 Fleetside
My truck has a 58 Impala rear end in it and I know the explorer rear is an 1 1/4 narrower, I think it's 60.5 if I remember right. The explorer rear is an 8.8 which is stronger than a 12 bolt, no shortage of 3:73 limited slips and no shortages of them in the junkyards. From what I can tell, it looks like it will hook up to the original parking brake cable pretty easily. I got the rear end, the aluminum drive shaft from the same truck, and a telescoping column out of and 67 caddy for $160 bucks. Was trying to cut corners where possible since we both know the No limit kit isn't cheap. The limited works for me since this truck is going to be my daily driver and not pro street like yours. The bolt pattern is 5 x 4.5, but I planned on running dual pattern rally's anyway.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-16-2010, 09:09 PM   #34
Tchia65
Re: 58 Fleetside
More progress.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-17-2010, 10:02 PM   #35
Tchia65
Re: 58 Fleetside
Front end mostly done. Motor goes in tomorrow then rip the back apart.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 10-19-2010, 02:40 AM   #36
Tchia65
Re: 58 Fleetside
Motor is in but the hoist decided to tip and the motor hit the firewall. boo
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-01-2010, 03:10 AM   #37
Tchia65
Re: 58 Fleetside
Been busy and progress slow, Been working on the rear. Got the the four link in and finally got to check out the stance tonight. Got a lot of cleaning up to do.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-01-2010, 10:02 AM   #38
upon1
upon1's Avatar
Re: 58 Fleetside
Truck is looking awsome! What are you doing for engine wireing and fuel pump?
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 12-01-2010, 10:48 AM   #39
Kim57
Kim57's Avatar
Re: 58 Fleetside
Looking good.
Kim
Kim57 is offline   Reply With Quote
Old 12-01-2010, 04:16 PM   #40
Tchia65
Re: 58 Fleetside
Thanks, I got a harness from turn key performance. I have not addressed the fuel pump issue yet. This is my first fuel injected swap. Any recommendations?
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-03-2010, 12:58 AM   #41
Woodbutcher
Woodbutcher's Avatar
Re: 58 Fleetside
Your truck's looking pretty good; I like what I am seeing. You work fast! But i gotta ask, after seeing your front suspension assembled and your urethane bushings... are they making any noise when you lif the control arms? If not, how did you deal with it? Mine make a ton of noise and I'm not happy with it, got side tracked with a house project and habven't got back to it 'cause I havent found a solution yet. Any ideas?
If the women don't find you handsome, they should at least find you handy... Red Green
Keep your stick on the ice, Woodbutcher
Woodbutcher is offline   Reply With Quote
Old 12-03-2010, 03:20 AM   #42
Tchia65
Re: 58 Fleetside
I haven't noticed any yet. All my others have urethane and they make some noise. I guess it doesn't really bother me. I have put grease on the bushing face with temporary success. If it really bothers you what about a needle bearing friction washer? Might work.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-03-2010, 09:09 AM   #43
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 58 Fleetside
Very nice build. Sits nice and low.
What size are the front rims?
They look like gm rally rims but have a bit of off set to them?
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-03-2010, 01:55 PM   #44
Spackle100
Re: 58 Fleetside
I have heard that silicon spray lubricant can help with this.
Spackle100 is offline   Reply With Quote
Old 12-03-2010, 07:18 PM   #45
Tchia65
Re: 58 Fleetside
They are rallys. I have 15x7's and 15x8's. both have a 3.5 - 4" offset. Going to get the fenders on and see which on works best then powder coat them. I am going to run smooth caps and trim rings from early wheel. Thanks for the compliment, you have a beautiful truck. TJ
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-03-2010, 07:20 PM   #46
Tchia65
Re: 58 Fleetside
Any type of lubricant for high pressure use should be fine. I used to use silicon spray on C-130 landing gear tracks. Works well.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-04-2010, 01:26 AM   #47
LEEVON
LEEVON's Avatar
Re: 58 Fleetside
Word of caution on the silicone, keep it far away from anything you plan to paint in the future.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-04-2010, 09:15 AM   #48
entourageguy
Yellow truck club
Re: 58 Fleetside
something like this ...
Name:  w.w trim ring and center.jpg
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-04-2010, 09:21 AM   #49
Tchia65
Re: 58 Fleetside
Attachment 664329
Yes, exactly like that...
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 12-04-2010, 10:49 AM   #50
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 58 Fleetside
It looks awesome laying out on the ground!
ChuckDriver is offline   Reply With Quote
