Old 09-23-2010, 09:59 PM   #26
BHyatt
Re: 200R4 Swap ?
Big thing I noticed was the view looking down around the motor to the ground with the hood up. The 2004R is a lot narrower than the TH350.
BHyatt is offline   Reply With Quote
Old 09-23-2010, 11:50 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 200R4 Swap ?
Got mine mounted up and bolted in the rear position. Drive shaft is a bit further into the trans then I want....but then again I haven't got the rear end exactly where it needs to be.
oh....and I came across this diagram of a 200-4r the other day.
current drive shaft position:
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-24-2010, 06:13 PM   #28
Mondo
Mondo's Avatar
Re: 200R4 Swap ?
I've had one in my 67 for a couple years now. The only issue I have is that it won't kick down out of lock up until there's a lot of throttle (or tap the brakes but it goes right back into 4th). It's a pain when in 30-45mph traffic as it lugs the motor. I've been to 3 tranny shops for adjustments but it hasn't worked out.
My solution was to put in a small dash toggle switch connected to the brake switch sensor and switch off the lock out when cruising around town (back to basically a turbo 350).
Do you guys have any problem with it releasing 4th gear lock up at a reasonable throttle position? Maybe I should continue my search for a tranny swap expert.
Mondo is offline   Reply With Quote
Old 09-24-2010, 06:33 PM   #29
ebfabman
Re: 200R4 Swap ?
I only use the lockup over 60mph.
ebfabman is offline   Reply With Quote
Old 09-24-2010, 07:04 PM   #30
68GMCCustom
Re: 200R4 Swap ?
for a 200-4r only one name comes to mind....Art Carr.....California Performance Transmissions. http://www.cpttransmission.com/
Kurt -
Old 09-04-2013, 08:41 AM   #31
19702wdc10
Active Member
Re: 200R4 Swap ?
I am looking to put a 200 r4 behind a chevy 250 3 speed also and was wondering what flexplate and torque converter you are using?
Joe
19702wdc10 is offline   Reply With Quote
Old 12-17-2013, 06:59 PM   #32
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: 200R4 Swap ?
I would also like more info on installing a 200-4r behind a 250 I6, has anyone done more research since 2010?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
