#26 |
Re: 1bbl Rochester... fustrated need help.
Here is more...
63AROD ![]() |
#27 |
Those small parts came off the top of carb where the choke connects...please tell me they are able to go back on and stay...hahaha.
Thanks fellas that what i got.
63AROD ![]() |
#28 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Would buying a rebuilt carb be out of thev question? It might come with the choke bracket that's missing, new springs etc.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#29 |
http://www.autoline.ca/carburetors.htm
Look in the Chevrolet section!
#30 |
Aerotruk63, no it wasnt out of the question I acually was going to have to do that until Geezer#99 mailed me out a rebuilt one for free. He's the man.
What Im trying to do now is put it back together so I can run it and wait for the mail man all day until it comes, hahah
63AROD ![]() |
#31 |
Nice pics. What a wreck!!! In 10 days you'll see how those parts are supposed to work.
Aerotruck.FYI. I sent him my rebuilt carb today. |
#32 |
that top coil looking thing is throwing me off because I dont see it on anyone elses and I dont know if anything is missing and thats why they put that coil wrapped around to accomidate for whats not there.
63AROD ![]() |
#33 |
Sniff, sniff, that's a beautiful thing you've done. LOL
#34 |
thanks again Geezer#99, yeah a wreck is right! And it being my first time at a carburator period you know why now im scratching my head. 10 days and counting!
63AROD ![]() |
#35 |
off to cause a bigger head ache... be back later to hopefully show it back together.
63AROD ![]() |
#36 |
OK I PUT THE CARB BACK TOGETHER... MY DELEMA NOW IS THE RIGHT AIR AND GAS MIXTURE IS NOT GETTING INTO THE CARB. ITS TO MUCH AIR NOT ENOUGH GAS.... THE TRUCK IS BACKFIRING AND WONT GO OVER 20MPH WHEN MY FOOT IS ON THE FLOOR.
ANYWAY THE THROTTLE LINKAGE WAS A JOKE TOO. I TRIED TO FIX IT BEST I COULD. MY BRAIN HURTS.... ![]()
63AROD ![]() |
#37 |
Guess I shoulda put the linkage in your care package too. Looks like another small package coming your way. Then you can hook it up right.
Backfiring could be caused by retarded timing too. I run an Hei with 12 degrees btdc. Try more timing. |
#38 |
geezer #99, I just got the Carb this morning in the mail... Im excited. Going to put it on this weekend. I'll post the updated pics when I can. Thanks again. Oh and I ended up just getting a timing light and now the timing is right on. I changed points, rotor cap, and condensor as well. Thanks again for your help...
63AROD ![]() |
#39 |
i just found a HEI distributor for the inline 6 on ebay for $80 incl shipping. Would that be worth the upgrade?
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
#40 |
that would be, I just did the basic rebuilding on mine but in the end need a new one, the shaft is loose. I'll take a look at ebay, thanks
63AROD ![]() |
#41 |
i had done the usual stuff, just like u and I was still getting a popping under load in the exhaust. I adjusted the points again and reset the timing and it is better, but I think I'll go with the HEI and then see how she runs. I also have to adjust the rockers. Slight tapping noise under the valve covers. The points gap is 0.016-0.019 i believe and the timing ended up on mine being 4 advanced.
#42 |
Exactly on the timing. I have that tapping noise too, so I'll look into that. Right now I have to feather the gas pedal so it doesnt stall in 1st gear. I dont even have the air cleaner on the carb right now because it was pressing the choke linkage down and causing the truck to blow out black smoke. I need a new choke cable to, I found the one on there is too short. Little by little I guess.
63AROD ![]() |
#43 |
U gotta love these old trucks. I'm pretty sure when the rebuilt carb goes on it will make a huge difference. How is ur exhaust/intake manifold? Any leaks? Coz now is the time to plan that job, if u are taking off the carb etc.
#44 |
Yeah Ive been planning that. I wanted to split the exhaust so that may happen, it may not. depending on how much time I have. Its a daily driver so? But I already bought the gasket for it so Im good there.
63AROD ![]() |
#45 |
Wow!!! Just a week to get there. Glad we could brighten your day. Of course ya know the warranty is up. JK. Go slow. Take your time installing it. Some tips for you.
When you pull the old carb off stick a rag in the manifold. Keeps crap outta there. Don't forget to pull it back out. Bolt the new carb down evenly. Snug and then a bit more side to side till it's tight. I included the stud and wing nut for your air cleaner. Stud screws into the hole on top. Looks like your choke cable will be long enough. If not you can peel a little of the coating off and remove a bit of the outer sheath. Wire cutters work. I looked at your pics. The clip that holds the threaded rod onto the swivel bracket at the firewall could be used on the short rod on the carb. Just see how it hooks on and install the same on the other rod. If you don't have an extra clip you could drill a hole through the threaded rod where you take the clip from it and hold it on with a cotter key. Cover the top of the carb with a rag when working around the top. You don't want any foreign objects falling in. I've had the pleasure of tearing things apart to find a lost nut nestled up beside a valve before. Any questions. Ask away. |
#46 | |
Best mod I made for a six. |
#47 |
Im sure I will have questions... I'll post the pics when Im done..When it came I could just smell it when it came out of the box.. the best smell, metal and gas!
63AROD ![]() |
#48 | |
#49 |
Nevermind, it's the same one I was looking at Whiteperformance1 is the ebay store, right?
#50 |
