Old 08-06-2010, 01:13 PM   #26
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Really Annoyed
If it's not even clicking, but the brake light is coming on, then you are not getting enough voltage to the solenoid. I would clean the battery terminals, check the battery ground cable, make sure it is grounded to the block and not anywhere else. If that does not do it, replace the battery ground cable. When I got my truck, the po had the ground on the core support. It eventually got to where I would turn the key and it would just "bump" the engine, and if I kept turning the key a couple times, it would turn over and start up. I moved the ground to the engine and have not had trouble since.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 08-06-2010, 01:21 PM   #27
67chevy1series
67chevy1series's Avatar
Re: Really Annoyed
that same thing happened to my dads 70 and it was the starter ubendix the wire wasnt hooked up so check that and the ubendix
67chevy1series is offline   Reply With Quote
Old 08-07-2010, 11:40 AM   #28
FriscoDave
FriscoDave's Avatar
Re: Really Annoyed
I had the same problem. Changed the battery, cables, and starter/solenoid. Had full length headers. Used this relay and haven't had a problem.
http://www.summitracing.com/parts/PRF-30202/
FriscoDave is offline   Reply With Quote
Old 08-07-2010, 12:04 PM   #29
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Really Annoyed
I bought a solenoid heat shield and a remote solenoid kit. The heat shield has worked so well that I never installed the solenoid kit. My damn truck would not restart after a 15-20+ minute drive until it cooled. I've since driven it on several 2-3+ HOUR trips and it will fire right back up after it's shut off.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-07-2010, 06:56 PM   #30
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Re: Really Annoyed
Originally Posted by Shyguy View Post
You probably need to replace both battery cables and clean up the connections. That is what I had to do to my 4-Runner with the same symptoms.
Just did the same to my GrandCherokee with 74,000 miles on it. Failure to start (or even click) stranded me twice in the 100+ heat & one time after that in the down-pouring rain following the hot spell.
New cable ends (at the battery only) got me starting reliably again. The old ones were corroded even down inside the wire insulation about an inch back from the terminal ends. Never seen that before. Cheap-cr*p foreign wiring battery cables, no doubt.
What-uh-yuh expect on a $ 30 K plus car---- that they'd use the good stuff ?????????
68shortstep is offline   Reply With Quote
