Old 10-17-2011, 08:54 AM   #26
78BO
78BO's Avatar
Re: Let me know how im doing ?
Originally Posted by kcfirstbuild View Post
Thanks - Now if i can get some one from the board to do body work !!!!!
Ok. I know it might be a sore subject, but you have to explain how you dropped the engine.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 10-17-2011, 10:12 AM   #27
c10/72
c10/72's Avatar
Frames looking great. You gotta tell us what happen with the Engine!
Tex (USAF)
-72 C10 SWB--bagged on 22"
-79 Mini Cooper pickup--on hold
-95 Chevy Dually Crewcab--tow-rig
-06 Magnum Hemi RT--wifey's
-06 Yamaha R1--fun times
c10/72 is offline   Reply With Quote
Old 10-17-2011, 11:05 AM   #28
wicky
wicky's Avatar
Looks nice
wicky is offline   Reply With Quote
Old 10-17-2011, 12:41 PM   #29
67cheby
67cheby
67cheby's Avatar
great work, very nicely detailed
67cheby is offline   Reply With Quote
Old 10-17-2011, 02:18 PM   #30
kcfirstbuild
I borrowed an older engine hoist one where the eye bolt runs up from the bottom with a nut on the top. I didn't check to see if that was tight. I should have just didn't think of it. AND pop two inches away from the frame and our feet. It stripped out the nut !
kcfirstbuild is offline   Reply With Quote
Old 10-17-2011, 02:41 PM   #31
hayhauler71
hayhauler71's Avatar
Looks very good. Job well done
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-17-2011, 03:11 PM   #32
78BO
78BO's Avatar
Well if that isn't a kick in the pants! I hate it when I do things like that.
Old 10-19-2011, 08:52 AM   #33
kcfirstbuild
YOu guys didn't hear me screaming !!!! - Eight hundred dollars later all fixed.
Old 10-19-2011, 01:23 PM   #34
treveiger
treveiger's Avatar
Looks good! How bad was the motor hurt?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 10-19-2011, 08:15 PM   #35
kcfirstbuild
OH you know !! - Only bent the crank, I have a good customer of mine that helped me out. Took it to his machine shop and his face said it all. The dial moved time degrees. So new pan, pump, oil pump drive shaft, Crankshaft, harmonic balancer, and new gaskets. Then for fun we dyno-ed the Little 307. Just to set the timing and make sure I didnt wreck anything else. It made 183, Should have made 200 but I used felpro permatorque head gaskets which he thought were a bit to thick and thats were i was losing my compression. I don't feel the need to tear in to in for the third time some i'm leaving it as is. Im not building a street machine.
Old 03-17-2012, 11:31 AM   #36
kcfirstbuild
Well, I'm finally getting some body work done. All the rust has been cut out and replaced . Just sprayed some 3m undercoating on it just needs one more coat and thats done.
Old 03-17-2012, 11:34 AM   #37
kcfirstbuild
Here's the picture.
Old 03-17-2012, 12:41 PM   #38
bcutt
bcutt's Avatar
Coming along nicely!!
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 03-17-2012, 01:52 PM   #39
bruceman1968
bruceman1968's Avatar
KC, Your doin great! The truck looks really good. Nice job, well done.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-17-2012, 03:47 PM   #40
Squirrelofdeath
KBS coatings for the black frame paint - thanks everyone
How do you like the KBS paint? I read somewhere that it can start setting up in the can after it gets opened, so I'm scared to start mine until every single part is prepped and ready for paint. Kind of a pain since I have some cross members and a-arms ready to go back on before I pull my cab.
Squirrel of Death
Squirrelofdeath is offline   Reply With Quote
Old 03-17-2012, 05:40 PM   #41
lmac1210
lmac1210's Avatar
I think it looks AWESOME!!!! I hope I can come even close to that!!!
Mac
1970 GMC SWB
1971 Chevy C-20 Longbed
Driving Miss Maybel:
http://1970gmctruck.wordpress.com/
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=513475
lmac1210 is offline   Reply With Quote
Old 03-17-2012, 06:00 PM   #42
kcfirstbuild
I learned that lesson real fast with the first can. What I did was use two screws and drilled them in the top of the can. Never opening the can. One to poor out of and one as as a vent. Didn't have much of a problem after that. I think it worked better sprayed on then brushed on.
Old 05-24-2012, 08:37 PM   #43
kcfirstbuild
Finally got the frame rolled out of the barn after a long nap in the barn over winter. I am glad to say i finally put the motor in just last night. This time it went as planned, no problems.
I'll post pictures some time soon.
Old 07-01-2012, 07:31 PM   #44
kcfirstbuild
More Work done !
Old 07-01-2012, 09:38 PM   #45
bmfm64
bmfm64's Avatar
Looking good! Keep up the good work!
bmfm64 is offline   Reply With Quote
Old 07-01-2012, 11:42 PM   #46
67cheby
67cheby
67cheby's Avatar
Looks great !
Old 07-02-2012, 10:23 AM   #47
ole dollor
ole dollor's Avatar
Man....you are on your way to one very nice truck...looks like you know what your are doing...and doing it right....
ole dollor is offline   Reply With Quote
Old 07-02-2012, 12:50 PM   #48
vanceman
Where did you get the brake lines? How was the fit?
vanceman is offline   Reply With Quote
Old 07-03-2012, 08:42 AM   #49
kcfirstbuild
Brothers, pre bent. MOney well spent so far, I hate bending brake lines.
Old 07-04-2012, 11:30 AM   #50
67c10rustbuket
67c10rustbuket's Avatar
Wait a minute am I supposed to remove all the grease before painting?! Just kidding Your'e doing EXCELLENT! One of my friends dropped a motor also, his was a caster wheel broke and tilted down and that was enough to turn the whole engine hoist over. ouch! Is there a build thread for this truck or just this thread? I like this truck a lot!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
