Old 08-13-2010, 12:23 AM   #26
tim21391
tim21391's Avatar
Re: Truck stumbles when floored
what did u gap your plugs to? i assume that one u just dropped in was hei.. did u gap them to .045? because with points i gapped mine to .035 and then with hei i gapped them to .045
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 08-13-2010, 02:03 AM   #27
1968CHEVYC10
1968CHEVYC10's Avatar
Originally Posted by kevmic28 View Post
Id say change the fuel filter in the carb and run some seafoam through it. If it only gets run a few times a year that carb has got to be clogged up something good.
I took the fuel line off and I didn't see any kind of filter in there, is it kinda far back in the carb? I put some seafoam in there today and ran it for a little while, didn't notice anything but I figure it'll take awhile.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 08-13-2010, 02:04 AM   #28
1968CHEVYC10
Yeah gapped them to .045
Old 08-13-2010, 03:59 AM   #29
72shortstep
lovin' the lowcountry
72shortstep's Avatar
On my Q-jet, the filter is where the fuel line enters the carb on the front. Good luck!
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 08-13-2010, 11:45 AM   #30
1968CHEVYC10
Don't think there is one then, undid the flare nut and the adapter and didn't see nothin.
Old 08-13-2010, 11:50 AM   #31
1968CHEVYC10
Originally Posted by Ticker View Post
$20 says the timing is wrong - either the initial or the overall timing curve.
Where is the vacuum advance connected?
Here's a pic of where I hooked up the vacuum advance.
It's right below here the fuel line comes in.
Old 08-13-2010, 12:14 PM   #32
youhaveamonkey
Ok, a few things here. RECHECK YOUR TIMING. Just do it. It is not hard. That is first.
Then the carb. There is a place for a fuel filter it is in the picture that you posted. It says "filter" on the front of the carb. Pull out the flare nut, then take a larger wrench (dont remember what size) and back off the part that the flare nut goes in to. If there is no filter in there, there needs to be one. That would be your first step. If your carb isnt getting enough fuel to allow the secondarys to work, you will effectively lean your mixture each time you push the accelerator down, and bog down the engine.
Check your mixture. Get a vacuum gauge. Set the mixture screw where you have max vacuum.
The carb may need to be rebuilt. There is a book about q-jets. I was not a carb guy either, however, the only way you are ever gonna learn is to do it.
There is a book about rochester q-jets. It is like 20 bucks or something at barnes and noble or borders or what ever. get it. it is worth its weight in gold. With the book and a good re-build kit, you can do it. It is not hard. Just be gentle, follow the directions and get it CLEAN CLEAN CLEAN. the toughest part for me is the end where you are trying to put the two halves of the carb together with the metering rods. It is a bit of slight of hand type of thing, but it really isnt hard. I guess what I am trying to tell you: just do it. Probably needs it anyway. MUCH MUCH MUCH better than a can of Seafoam, but I cant say I disagree with the other guys on here about it....
Good luck!
Cheers!
youhaveamonkey is offline   Reply With Quote
Old 08-13-2010, 12:25 PM   #33
kevmic28
kevmic28's Avatar
Ok as fas as my carb goes, maybe this will help you out.
White circle is where the filter is.
Red circle over the vaccum tube is plugged on mine.
The yellow circle vaccum line goes to the choke.
Green circle: in this are is a vaccum tube that needs to be connected to the vacuum advance. also I have a tee from that tube to one under the choke that goes to the distributor advance.
Next is the clamps on your fuel filters, these have a tendancy to fail after some time and leak. Might consider changing to some screw drive clamps.
Now that is how mine is done. Mine could be wrong but it runs good this way.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 08-13-2010, 02:01 PM   #34
1968CHEVYC10
Wow thanks guys, yall are awesome! The vacuum advance is on the dizzy right? I was thinking that but you mentioned distributor advance, so I'm not sure.
Old 08-13-2010, 03:15 PM   #35
68 50th
68 50th's Avatar
I had the same problem, it turned out to be a secondarie metering rod that had slipped off the rod hanger and plugged one of the secondarie jets.
See this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=155657
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
