09-21-2010, 11:12 PM | #26 |
GM ONLY BABY!!!
Re: Which motor mounts set the motor back the most?
Yep, maybe too far back. Where mine is I was able to use the stock holes in the frame for trans. crossmember to bolt my 4L65 to.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
05-28-2011, 07:46 AM | #27 |
What motor mounts would you guys recommend if you want the motor to sit in the best position w/o having to do any frame trimming, if that can be done? i am running a 5.3 efi in a 70 frame, and i am not running a/c, but i might in the future. i keep reading about cpp mounts, ece mounts, and now i am hearing about all these others and how they affect the motor position. someone plz help clarify for me. thx.
1963 C-10 custom cab on a 70 swb leaf spring frame, 283/3spd rat rod 1986 crewcab 3+3 camper special 454/400 pig rig (soon to be bagged) |
06-01-2011, 06:28 AM | #28 | |
Home Built '87
My 87 build has some pics of how they look. You can always call Brent at Dirty Dingo as well to discuss how they would fit. I don't know firsthand about how they compare to the other brands.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 Last edited by Gordonr1973; 06-01-2011 at 06:28 AM. |
09-21-2011, 06:57 PM | #29 | |
Posted via Mobile Device |
09-21-2011, 08:57 PM | #30 |
Truck and auto performance nut
the sbc mounts will be toward the front... as the brackets mount on the block.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-21-2011, 09:39 PM | #31 |
cool thats what i thought. Thanks
09-25-2011, 12:37 AM | #32 |
I made my own by useing clam shells centered over the front holes on the lsx mount. I used 83-87 towers in the rear holes wich set the motor back about 1-" back my f body header (driver side) then hit the lower control arm. so i yanked the motor and moved the towers back as far as possible and drilled new holes in the fram and member. I ended up 2.25 back but then had to re do my fire wall because the motor hit. but I also have a 3" body drop. it may not hit on a stock set up. my long tube cleared the lower arms great but i still had to notch the frame some because the collectors kick out so far.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 09-25-2011 at 12:40 AM. Reason: add pic |
11-03-2011, 12:37 AM | #33 |
68gmccustom u got pics of firewall i like to see that.
2000 camaro SS,built 2006 GTO stock 1984 chevy 4x4 1967 chevy frame off rebuild under way,with 6.0,4l65e 1969 GMC 6.2 diesel th400 3:73 rear |
11-03-2011, 10:19 AM | #34 |
not really.....but maybe these will give you an idea. I actually could go back a bit further....and probably will some day.
01-03-2012, 10:19 PM | #35 |
68gmccustom, so did or didn't the trans rapt plates work with your headers? I'm confused so many options but I think I'm gonna try and run your same headers .my truck is currently a 6 cylinder so I was thinking your headers and trans dapt. 1" set back plates.
01-03-2012, 10:45 PM | #36 |
Yes, using the sbc towers, mounted in the forward position...with the 1" Trans Dapt setback plates the DynaTech '70-'81 Camaro LSx swap headers fit. The tubes were real close in a couple of places and I was concerned about motor movement so I trimmed maybe 1/8" off the top frame rail where the offending tubes were too close to the frame. With a motor plate or some retaining straps maybe I could have gone w/o trimming.
That said....my motor could go back another few inches ...and the headers would only fit better.
01-03-2012, 11:34 PM | #37 |
Has more rust than truck...
I tried the 6cyl stands with 1" set back plates, motor fit, trans (4l80E) hit my low hump cab. If I had a high hump I think it would have fit.
01-03-2012, 11:47 PM | #38 |
good to know....considering a 4L80e upgrade sometime in the future.
01-04-2012, 11:36 AM | #39 |
I used these and they set the motor back perfect, and are also the adjustable type. I'm not sure how much the other brands cost but I couldnt pass up this price.
http://www.ebay.com/itm/300633326560...84.m1423.l2649 |
01-04-2012, 06:52 PM | #40 |
I plan on mounting coil packs on rear of heads. So with sbc stands and trans rapt 1" set back plates would there be enough room for the coil packs? If I kept my 6 cylinder stands would they put me further back?
01-05-2012, 07:37 PM | #41 |
use the sbc mounts in the front/forward position with your 1" setback plates and you'll have plenty of room. that's where I'm at now. depending on the coil pack setup you use...you might even be able to go another 1" or so further back.
