09-08-2010, 06:41 AM | #26 |
Re: 1985 TBI Canadian Plainsman
Over here you would have to get a "state issued" VIN, if you decided to start over. It would bare no resemblance to the factory issued VIN interms of characters, meaning and sequence.
Regarding: "...someone said GM can reissue VINS": do you mean for vehicles where the VIN has been altered/defaced? No - that would be the state issued VIN above. Or - do you mean for vehicles that are shipped to outside conversion companies? Once again - no; once the vehicle leaves the assembly plant that VIN is supposed to be forever affixed and unaltered. I can even give an example: we are taking some North American 2011 "saleable" base vehicles and converting them to 2012 European nameplate "non saleable" vehicles. Even in this extreme case we will leave the VIN as it is (normally non-saleable vehicles get an "EX" VIN). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-08-2010, 01:48 PM | #27 |
78K & 79C Jimmys
I was told it was a converson done to a heavy half?
would that explain the 16 inch tires,on the door sticker? And the vin is ok and how can i tell if this was done
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-08-2010 at 01:59 PM. |
09-08-2010, 02:02 PM | #28 | |
Still plays with trucks
I did this after I had a tree fall on my truck and smashed the cab. Got a good used cab from the wrecking yard with a bill of sale and swapped all my parts onto it then put the truck back together. The state patrol inspection lanes guy removed the old VIN plate from the dash and riveted a new state tag onto the dash which had the frame VIN number stamped into it. It may take a little paperwork to find out the story behind your rig and track down the last registered owner of the frame VIN based vehicle. The police should be able to do this for you just to prove it is not stolen.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
09-08-2010, 04:21 PM | #29 |
78K & 79C Jimmys
how to tell? if the front axle etc was added,and i guess the tbi is then aftermarket
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-08-2010 at 04:26 PM. |
09-08-2010, 04:34 PM | #30 |
That SPID label is from a 1/2 ton suburban:
CV10906 = C = Chevy V = 4wd "R/V" style vehicle 109 = 1/2 ton, lwb 06 = Suburban. Just FWIW - K
09-08-2010, 04:47 PM | #31 | |
I have seen MD8 and MX0 on vehicles of mine with the 700R4 / 4L60 trans which also fits your drivetrain. The 8th digit W in the VIN you have correlates to a 454 for 1985 which would also have come with a T400 which if I remember right was option code M30. Makes me think there is some funny business with titles going on especially with Keith's statement that it was not possible to get TBI in 1985 in any form on a truck. The chassis looks correct and is most likely an 87 to 91 vintage setup from a half ton Suburban. You need to get a look at the chassis VIN and see if it has been obliterated too like the SPID tag and door tag. Look at the transfer case ID tag and see if it is an NP208 or an NP241. Also check to see if it has a speedometer cable or just a VSS sender on the transfer case. This will help us identify what year the chassis really is. The broadcast code on the ECM and the model number of the ECM will tell you too by looking up the application but many times these have been replaced so it is not a sure way to tell.
09-08-2010, 05:46 PM | #32 |
78K & 79C Jimmys
would there be front axle numbers some where if aftermarket.I was told the transfer was rebuilt on the way to Canada but in the US .And just today found number 984 stamped to the firewall
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-08-2010, 05:52 PM | #33 |
78K & 79C Jimmys
door number seemed funny with air pockets /worn out but told "it is an old truck" lol
09-08-2010, 06:01 PM | #34 |
78K & 79C Jimmys
door sticker was close enough it's for the vin in the dash
09-09-2010, 08:34 AM | #35 |
78K & 79C Jimmys
from what i see it's all there,and then some lol
09-10-2010, 06:27 AM | #36 |
78K & 79C Jimmys
still pokin at this thing........hasn't bit me yet lol.if it was a carb it would have less gas lines then a tbi?no numbers on the frame i can see.does gm offer/sell/have info that can be ordered from them on older trucks
http://chevroletsilverado.net/1985-chevrolet-silverado/ above website is the first to say tbi in 85 i have found
09-10-2010, 06:40 AM | #37 | |
Conversion Truck Addicted
its not the first time i have heard about TBI in 85 on trucks but i think keith would be the one to belive in as he was there and know what these trucks came with
Thomas Quote:
09-10-2010, 06:41 AM | #38 |
78K & 79C Jimmys
http://chevythunder.com/fuel%20injection%20history.htm
There has been minor changes over the years. The 1985 system is a one year only, as it has a separate "piggyback" mass air flow (MAF) control module on the ecm, and a one year only ecm, #1226870. It will not electrically interchange with the 1986-89 harness. In 1989, however the cold start injector was eliminated. In 1990, The mass air flow was eliminated and speed density control was introduced. It required a different harness and computer. This system was used all the way up 1992, where it was replaced by the shorter runner designed LT1 and LT4 power plants. not sure if they are talking tpi or tbi
09-10-2010, 08:04 AM | #39 | |
Right - but that's for passenger car. TBI was introduced in 1986 for M van, and 1987 for R/V truck. The idea was to roll the technology out on a smaller scale before releasing it across the full truck line (including the new C/K aka GMT400) in 1988. K
09-10-2010, 08:09 AM | #40 |
Not close enough: for example, there are no 16" truck rallys like you have on this Suburban (15" only). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-10-2010 at 08:13 AM. |
09-10-2010, 08:10 AM | #41 |
Motornut -
I think I'm starting to see what happened with your truck. I think it's a straight up VIN swap. I don't know why someone would do that in this day and age. Back in the 60s, the main reason would be because the vehicle was stolen. The SPID label matches the content on the body (as you have shown). It even matches the chassis content (powertrain and axles), which implies the chassis has not been altered. Everything here seems to add up and be a complete unit. The only thing that doesn't match the hardware you are showing is the VIN tag itself on the IP. The door sticker tag matches the VIN tag on the IP (but not the content on the truck) because a previous owner pulled it off a different vehicle and applied it to this truck (that's why the printing is so defaced and why it's so bubbly). You (or someone) covered up the VIN on the SPID label. I'd be willing to bet it does not match the VIN tag on the IP. Am I right? If so, then I'd say the original, unaltered VIN is the one on the SPID. Quote: "...It's an old truck." I think somebody is pulling your leg. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-10-2010 at 08:16 AM. |
09-10-2010, 01:03 PM | #42 | |
09-10-2010, 01:06 PM | #43 | |
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 09-10-2010 at 01:06 PM. |
09-11-2010, 02:25 PM | #44 |
78K & 79C Jimmys
It was looked at a gm dealer here wensday i was told the truck is a light duty 3/4 ton with a possibly aftermarket kit for the (15")four wheel drive.That this setup was done in Texas for trailering and to avoid emmissions,light duty 3/4 ton came with 6 bolt wheels, those rims/wheels are off my 87 4x4 (and the ones i got with it seem to match) to me it was the same truck ,till it drives as it always seemed heavier.I was worried bout it being stolen they checked it out said it matches and the explanation to me makes sense now.The tbi he said thought it was possible he had seen it before.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-11-2010 at 02:25 PM. |
09-12-2010, 08:37 PM | #45 | |
There was no light duty 3/4 ton (from the factory) - all 3/4 tons had 8 lug wheels; those are not 3/4 ton axles with any kind of conversion kit, either. Lastly, as we've said, there were no TBI's in full size trucks prior to '87. I don't mean to be harsh but you should consider finding another GM dealer. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-12-2010 at 08:37 PM. |
09-13-2010, 08:19 AM | #46 |
78K & 79C Jimmys
eitherway having owned the truck for 8 years,i'm not done sorting this out.Ive known the dealer for ever,we lost a lot of dealers up here,being one left must mean somethings been done right.Maybe you were off that day i duno i go by what i've been told,and you say no 3/4ton were built with 6 bolt axles....
http://67-72chevytrucks.com/vboard/s...d.php?t=127471 even here it says it,and would show that the truck was older like you say
09-13-2010, 08:24 AM | #47 |
Getting Old; Going Broke
Sad thing is though motornut, more than just a few are telling you how it really is and you're just not believing them/us. Is the main reason I quit posting on your stuff, you are believing what you want to believe and it's wrong.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
09-13-2010, 11:10 AM | #48 | |
I'm talking specifically the 73-87 C/K/R/V. I thought it was obvious, but should have said so. I worked on that product line exclusively, in both the assembly plant and engineering (design and development), from 1979 until 1992. I really hate to play the "I worked there so I know" card, but I should add that when the dealerships didn't know how to fix a truck (anywhere in the US) - I'm the one they called. You are free to believe whomever you like, but if you really want to get to the bottom of this I would encourage you to consider what we are trying to tell you. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-13-2010 at 08:26 PM. |
09-14-2010, 01:47 PM | #49 |
78K & 79C Jimmys
First let me say this is not something i have done to the truck myself.
Thanks for the help.i was being a smart ass asking if you were off that day. I did post a pic, here it is post 14, asking about the inside of the door marks there are marks melted in pointing up to the years 88. you mentioned, as i asked about the eng change was engineering,not engine.aside from what has been said on here (re:tbi,3/4ton)those marks on the door panel are the only thing that gives a hint of it being a later year,that i have found.(untill now this option of 6 bolt 3/4 ton wheels seems to start later too),if thats what this truck is. This 85 truck resembles everything in my 87 ,any parts i swaped over as needed,or refered to the 87 when ordering something not found for the 85 This is my first "forum" i have ever posted on re:trucks or cars. this all started because i was helping someone figure out their own truck.I don't care what setup it came with i'm more concered with it being stolen,or not. My gm dealer is one my family has known for 50 + years,so thats not gona change.When i brought the truck in it was not put on a hoist,nor did we even have time to lift the hood.the gentleman i spoke with was not a younger person,he surprised me with the info that i posted,and i felt he was informed and his answers made sense,with no reason to disbelieve him it was posted,as i understood it.As for not answering posts well thanks for not helping as i try to solve this issue,i thought people had just not seen the posts re: looking for frame numbers,hidden vins etc.Friends and I have gone over this truck i think fairly well looking for extra numbers,even after being told by some "helpful" members where to look,nothing was found. someone sent me an email re "Vintage gm" so i have contacted them and appears "if you pay they will say" what the options were,about $200. 100 is for Canada info,100 for the Us info,since the truck is from US i have to pay the 100 to Canada,first for info (if nothing found)then the extra for the US Is there an easier way?should i /could i just do a US check? any reason for a 8 in the vin? can the frame number location be narrowed down by someone? After 8 years of looking for info on the"Vacation Customs" a Texas company,( I now know more "customs done on vacations",and "custom vacation packages" than i care too). i have only ever found one other truck by them,and he's here too, but we still have no info. And what i read apparently if the engine/option was not offered,that year, it's excempt from the etest (here anyway 85 is now) ,maybe someone redid it trying to get around the test
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-14-2010 at 01:52 PM. |
09-14-2010, 02:25 PM | #50 | |
Motornut:
Is there a VIN on the SPID label? Does it match the VIN on the IP? Quote:
It also says the '85 had air bags, traction control, driver's knee air bags, rack and pinion steering and xenon headlamps. Most of those features were still years away. It's like they took that paragraph and copied it from somewhere else without even reading it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-14-2010 at 02:55 PM. |
