#26 |
Re: 96 Caprice (COP CAR) rear axle with disc brakes
I'm sitting on a goldmine. Lol I have like 4 ss rears, and 8 cop car rears. Lol also, I got brake shoes for mine not to long ago at napa.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#27 |
OK, mine seems to be missing whatever the e-brake is. I see a small lever and a bracket on the back side. Guess I need to look up replacement parts.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#28 |
OK, so it looks like everything is there but the cable for the funky drum parking brake thing. I just need to locate some cables. I will post pics in my build thread when I get more done.
#29 | |
Trueman |
#30 | |
#31 |
If u don't find new ones, I mighthave some good used ones. I have 3 9c1 cars left Out in the back 40
#32 |
Thanks, but at $13 a pop, they won't kill me to score some new ones.
#33 |
Can't beat that deal!
#34 |
Got everything cut off and ground smooth. The only question I have is do I cut off the "ears" or leave them?
![]() The don't stick up very high, but I don't want to have clearance issues with my bridge. The bed will be raised 9", so it might not be an issue to leave them.
#35 |
I have to ask, are you using a 4 link? Or are you welding the trailing arm pads to this rearend and using the stock trailing arms? I'm intrigued if this would work for my 71 stepper and how you are accomplishing this.
Thanks Glen Posted via Mobile Device
#36 |
The goal is to weld on the perches and use the Porterbuilt trailing arm dropmember rear. Same would apply using the stock trailing arms. Once I get the back half together, I will have the driveline shop set the pinion angle and weld on the perches.
That's the plan anyway. ![]()
#37 |
Nice, i was looking at one of the rearends i have, 323 gears out of a 4.3 95 9c1, no posi though, i might cut the pads and the ears off it, and see if i can't mock it up for my 71 just for the heck of it. I'll use the existing pinion angle from the stock rear (angle measurement anyway). Might be fun just to try it.
How low are you going? I have a lowering spring kit, and the shock relocation kit, but what is the dropmember for? Just to get you on the ground?
#38 |
I just looked up the Porterbuilt drop rear, WOW your going for the low! lol
#39 |
Mine shouldn't be as low as most dropmember builds, actually. But since talking to Boris about his Corvette brake kit, it might get 2.5" lower than anticipated.
![]() This forum is both a blessing and a curse. A blessing for my truck, a curse for my wallet.
#40 | |
#41 |
Sorry to drag up an old thread.........but just to be clear.
If I want the narrow rear differential with 8.5 ring gear and rear disc brakes.....what cars do I look for? Or even one with drums......not a deal breaker by no means. Thanks..
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
#42 | |
My rear is the 9C1 (I was told) and I am trying to figure out if the wheels I want to run will fit. Chopper John had 15x7 reverse laced wheels that only have a 2" backspace and his fit with minimal work. The wheels I am looking at are 18x7.5 +51mm offset, so close to 4" or so of backspace. But with my rear end, it looks like I don't have nearly enough room to stuff those wheels.
#43 | |
Is the 9C1 the one to get? Narrow with discs i think? Trying to find one to use for a 1997 c1500. Want to do disc and have narrow rear for more lip on wheel.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
