Old 09-07-2010, 03:42 PM   #26
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Just bought some calipers, any ideas if I can make them fit?
I started the True C5 Rear Disc w/ internal parking brake in the works thread and will have a matching solution to the McGaugys 13" fronts (brackets are getting cut this week... I was also thinking about using the 13" rear C6z06 rotors but they only come cross drilled... and you would have to buy the front to have a matched look.. Im not sure if the rotors (c5 and zo6) are the exact same offset but just larger? if they are you could just use a c5 caliper on the zo6 rotor and still have the internal ebrake...
I havent gotten that far with mis-matching corvette parts... plan to
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
