Old 11-29-2010, 05:49 PM   #26
Pro Performance
Pro Performance's Avatar
Re: 84 C10 Project
Originally Posted by baclay9 View Post
What engine paint did you use. I was thinking about doing mine in those same colors and really like the way yours looks! Great job man!
Thanks.
I used the high heat paint from Oreilly's. I can't remember the brand, but I will check when I go back there next. I know the color was called "Cast-Iron", but it came out with a greenish tone.
Pro Performance is offline   Reply With Quote
Old 11-29-2010, 05:53 PM   #27
Pro Performance
Re: 84 C10 Project
Originally Posted by kikkegek View Post
wow! youre engine looks really sweet! I love the stealthy black you gave it.
but it sounds like you are starting it all the time, like it is not running on its own.
Youre ignition timing is an easy option/solution.
unscrew the screw under the distributor about 1/4. Then start your engine en rotate the ignition either way. If it gets worse, rotate the other way. you should hear the engine starting to run better.
I recently did this myself and it is real easy to hear. If you do not have a timing light, you can set the ignition yourself by ear.
almost forgot. before you start your engine, unplug the vacuum connection to the distributor and plug it. after adjusting it you can connect it again.
goodluck
I set the initial timing at 12 degrees advanced, and it starts and idles great, but once you give it throttle, it just bogs and chokes up and sputters. It has something to do with the vacuum advance, I think. Either it isn't advances it enough or advancing it way too much. I think 36 degrees total is max, and should come in around 2800 RPM.
Old 11-29-2010, 09:47 PM   #28
evan
evan's Avatar
Re: 84 C10 Project
The thing in the red circle is a charcoal canister.
Evan B.
evan is offline   Reply With Quote
Old 03-14-2011, 06:18 PM   #29
Hulk Will Smash
Hulk Will Smash's Avatar
Re: 84 C10 Project
Just noticed you're a fellow OC guy. Looks like this truck is coming along nicely! I'll look forward to givin' a big thumbs up when I see you cruisin' PCH sometime.
Keep up the good work dude!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 05-02-2011, 11:41 AM   #30
Pro Performance
Re: 84 C10 Project
Been a while since I posted or even worked on my truck. But here are some updates. I am planning on getting it painted this summer, so I finally got the new doors (with full power) hung, and aligned.
I want to paint it that copper color that comes on the corvettes. SO, bodywork will start soon. I need to find a new bed, and a new hood.
Old 05-03-2011, 11:53 AM   #31
Pro Performance
Re: 84 C10 Project
Found a bed on craigslist yesterday. Straight with no rust and already has the fuel doors shaved, with a opening in the bed for the filler neck.
Got it for $220 with the tailgate.
Old 05-03-2011, 07:17 PM   #32
87 chevy silverado
Re: 84 C10 Project
not bad
87 chevy silverado is offline   Reply With Quote
Old 05-04-2011, 04:33 PM   #33
Pro Performance
Re: 84 C10 Project
I think once the bed is off, I am going to airbag the rear and prime the rear of the cab.
Old 05-13-2011, 01:35 PM   #34
Pro Performance
Re: 84 C10 Project
I ordered some of the bag components..... well enough to bag it and use schrader valves for now. I still need tanks, valves and compressors. I just wanted to get the bags and brackets on while the bed was off.
I ordered the brackets & c-notch from KP Components and will be using Slam Specialties SS-7 bags. Should be here all next week.
I am keeping everything under the bed.
Old 05-13-2011, 01:50 PM   #35
luifer76
luifer76's Avatar
Re: 84 C10 Project
great progress man,.. truck is gonna look really nice all bagged looking foward to se more progress man keep the pics coming and great job so far.....
luifer76 is offline   Reply With Quote
Old 05-13-2011, 02:40 PM   #36
Pro Performance
Re: 84 C10 Project
Thanks. I also want to repaint the frame when the bed is off, but I am also considering the POR15. I have never used it, but the end result looks good and seems easy to do.
What would you all recommend?
Old 05-13-2011, 03:24 PM   #37
spudz
spudz's Avatar
Re: 84 C10 Project
I like it alot!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 05-18-2011, 11:00 PM   #38
Pro Performance
Re: 84 C10 Project
Parts came in from KP Components. Can't wait to get the bed off and start on the suspension and cleaning up the frame.
Old 05-23-2011, 01:22 PM   #39
Pro Performance
Re: 84 C10 Project
Got the bed pulled and ready to c-noth and airbag the rear. I am looking to POR15 the rear frame, but have read mixed reviews.
What do you guys thing of using that stuff? Does it adhere Ok? How is the satin black color? Does it lay down consistently? What is the best way to apply?
Old 06-07-2011, 01:09 PM   #40
Pro Performance
Re: 84 C10 Project
Got the c-notch in. Next will be to weld it up, and start making the crossmember for the bag brackets. I still have not decided on how I will be painting the frame, whether it be POR15 or some sort of chassis paint from Eastwood or Summit. I will be wire wheeling to remove all the paint first though.
Old 06-10-2011, 01:10 AM   #41
Pro Performance
Re: 84 C10 Project
Took some time today to do some renderings to start deciding on what color I want to paint the truck. Here are a few ideas. I am going to be running door handles, just haven't added them yet. I am planning on taking (2) front bumpers and piecing them together in order to remove the license plate pocket. If I run a rear bumper, I will be doing the same back there.
Dark Red with Dark Charcoal Wheel Centers
Dark Red with Brushed Wheel Centers
Orange with Brushed Wheel Centers
Yellow with Dark Charcoal Wheel Centers
Old 06-10-2011, 01:45 AM   #42
kikkegek
kikkegek's Avatar
Re: 84 C10 Project
he man! nice renderings, what did you do the rendering with? looks awesome!
kikkegek is offline   Reply With Quote
Old 06-10-2011, 04:14 PM   #43
Pro Performance
Re: 84 C10 Project
Thanks..... I did them using photoshop. It does help that I am a graphic designer for a living.
Old 06-10-2011, 04:16 PM   #44
kikkegek
kikkegek's Avatar
Re: 84 C10 Project
3D renderings in Photoshop? man! I am getting old! is that a new feature?
Old 06-10-2011, 04:40 PM   #45
Pro Performance
Re: 84 C10 Project
I started with a photo, and then modified it from there.
Old 06-11-2011, 07:53 PM   #46
Pro Performance
Re: 84 C10 Project
Got the rear airbag setup pretty much done. I still have to figure out where I am going to mount shocks. I haven't tried it yet, but I was told the 1-1/2 square tube will fit underneath the bed.
Old 06-11-2011, 10:22 PM   #47
Cherub
Cherub's Avatar
Re: 84 C10 Project
will any of this setup interfere with the bed?
Cherub is offline   Reply With Quote
Old 06-11-2011, 10:24 PM   #48
Pro Performance
Re: 84 C10 Project
That is my concern, but a local air suspension shop (a friend of a friend) said it would not. Is it possible to maybe measure the space between your bed and frame in that area where I have the crossmember? It is placed right above the drivers side shock mount. That would be a huge help if you were able to.
Old 06-11-2011, 10:46 PM   #49
Cherub
Cherub's Avatar
Re: 84 C10 Project
Just went out and checked. directly above the driver side shock mount is a brace for the bed.
Old 06-11-2011, 10:49 PM   #50
Pro Performance
Re: 84 C10 Project
Thanks for checking. It is hard to do that when my bed is upside down.... it is hard to reference exactly where that is.
Maybe I can remove that bed brace??? So, there is no room, it comes right down onto the frame?
If that bed brace was gone, would there be enough room for that 1-1/2" square tube?
