Old 09-02-2010, 01:35 PM   #26
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Air Cleaner Intake Hose and Clamps
Originally Posted by tucsonjwt View Post
Thanks for the excellent research. Do your stock hoses have a 4" opening on the round end, and about 5.25" across the flat where it connects to the air cleaner, and about 24" long?
Sure does
Malo83 is offline   Reply With Quote
Old 09-02-2010, 01:47 PM   #27
RandyP
Getting Old; Going Broke
RandyP's Avatar
Yes, the one you have on your truck is the same that I removed from my 87. The core supports are the same 81-87 for all 1/2 and 3/4 trucks (probably for 1 ton as well). I know your connection is probably just like the one in these photos. Sorta tells me the duct I have on my shelf here, which is from this core support (87), is what you need. Although I guess the air cleaner could be different, which could change everything as far as length needed etc.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-02-2010, 03:10 PM   #28
tucsonjwt
The opening in the core support is the same. The connection adapter I have is different - just an open sleeve which I assume the duct fits over or into - not fancy like yours.
tucsonjwt is offline   Reply With Quote
Old 09-02-2010, 03:26 PM   #29
Keith Seymore
Keith Seymore's Avatar
Joining late, you guys just about have everything figured out, but here are my comments:
a) You are correct, ducts snap over the air cleaner base and over the "birdcage" in the radiator support. No clamps.
b) Big block (454) air cleaners had a larger snorkel opening than the small block versions.
c) The difference you are seeing at the radiator support is that one of those is the typical "birdcage", which attaches to the duct on one end and has the protective cover on the other; the other device is an optional "water separator", available by selecting the specific RPO (I don't recall off the top of my head what the RPO was). That's why you won't see that on every truck (should be pretty rare, actually).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-02-2010, 03:34 PM   #30
RandyP
RandyP's Avatar
For the 89-91 Suburban/K5 you can not use the normal round core support that goes through a hole, there is a headlamp there. That's why it has a different connector that draws air from below, and it actually bolts on since it has no where to slip through and twist. Anyone that has the "burb clip swap" and kept the factory air cleaner and duct, should have that. I think.
I've learned quickly that I'm wrong a lot though.
Old 09-02-2010, 03:47 PM   #31
tucsonjwt
Thanks Keith. I finally got a p/n from the local Chevy dealer (a minor miracle)(discontinued, of course) - 14024596. Vintage parts has them so I guess I will order one and give it a go. I hope my plain round connector at the core support is all I need to make it work.
Old 09-02-2010, 03:59 PM   #32
nbpro
I'm wrong a lot even if im right, in my ex wife's eyes. Keith, you da man. I kept forgetting it was a 454
nbpro is offline   Reply With Quote
Old 09-02-2010, 04:06 PM   #33
Malo83
Cruzzzn' Vet
Malo83's Avatar
Tucson, this how my sleeve looks on my 83,basically the same as Randys pic except I cut off the front flat plate that sits in front of the adapter to give a ram air effect at speed.
Uploaded with ImageShack.us
This is looking from the front,
Old 09-30-2010, 06:54 PM   #34
tucsonjwt
I got the intake duct from Vintage Parts and it fits perfectly. P/N 14024596
About $32 delivered - not bad, considering the little piece of crank vent hose was $43.
Old 09-30-2010, 10:13 PM   #35
Shawn5488
Is there anyway you can get your parts guy to get the big block air cleaner hose part number? Mine is a '85 so no TBI, I know they are different. Thanks!
Sounds like we might be able to get these after all.
Anyone ever used the stock air cleaner to make a dual air snorkel air intake? I have always wanted to make one that was stock looking. I know the a\c compressor will be in the way but I am switching to a serpentine conversion so I should be good to go...
Shawn5488 is offline   Reply With Quote
Old 10-01-2010, 12:01 AM   #36
sixshooter798
Desert Rat
sixshooter798's Avatar
I got this one for $5 at the local junkyard.
sixshooter798 is offline   Reply With Quote
Old 10-01-2010, 06:31 AM   #37
D13
D13's Avatar
7 and 8 are diesel silencer parts.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-11-2012, 09:37 PM   #38
rruss86
Small issue.. Vintage parts will not sell to just anyone.... I have to be a retailer..
rruss86 is offline   Reply With Quote
Old 01-12-2012, 06:29 AM   #39
tucsonjwt
That must be something new. I bought my air duct from them last year. Just went online with my GM OEM part number and followed the prompts with my credit card - no problem with the order or delivery. AIRC there was a different pricing schedule for dealers vs. retail customers.
Old 10-09-2012, 03:25 AM   #40
kikkegek
kikkegek's Avatar
he guys, I finally got my hands on the grille insert and a new hose...hard to get her ein the Netherlands.
But it seems like I need a part to connect the two?
do I? please advise
I still take the air cleaner of regularly, so dont want to duct tape them together... :-)
kikkegek is offline   Reply With Quote
Old 10-09-2012, 05:30 AM   #41
INSIDIOUS '86
INSIDIOUS '86's Avatar
Incorrect hose.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-09-2012, 06:36 AM   #42
kikkegek
kikkegek's Avatar
Originally Posted by INSIDIOUS '86 View Post
Incorrect hose.
thanks, can you show me the correct version?
Old 12-28-2012, 12:26 PM   #43
ghostflyer
Anyone have a part number for this part?
Thanks, Les
ghostflyer is offline   Reply With Quote
Old 12-29-2012, 06:30 PM   #44
blakeduren
Just to follow up on some stuff:
I thought I would post a pictures of the TBI air cleaner snorkels.
The longer one is the 87-88 one.
The shorter one is the 89-91 one.
Classic Parts sells the 87-88 one. I purchased one for my truck. I took a TBI aircleaner with out extra holes in it, and took out the hot air valve stuff and patched the hole. So now my 83 suburban with a 454, only gets air from the front core support, I also shaved the potective front cover off like the guy earlier in the thread did.
If anyone wants the 89-91 one, let me know.
blakeduren is offline   Reply With Quote
Old 04-10-2013, 01:30 AM   #45
JellyBeanDriver
Just put in an order for one today from LMC for our 86' C30, carb'd 454. Hope it fits.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 04-16-2013, 11:11 PM   #46
JellyBeanDriver
Received my LMC order today. Took it out of the box and thought it was made wrong as the 4" end to the core has a slight angle to it and that angle is not in the same plane as the end that connects to air cleaner.
HOWEVER, installed it and it was a perfect fit. Nice and tight on both ends, the ramps/catches fit where they were supposed to.
Yay! No more sucking in hot, post-radiator air.
Old 04-17-2013, 03:51 PM   #47
Malo83
Cruzzzn' Vet
Malo83's Avatar
Ordered mine from LMC also
Old 04-19-2013, 12:05 AM   #48
wraprail
wraprail's Avatar
I trip over these things everytime I'm at pic-a-part. Just lying on the ground everywhere. Crazy you guys have trouble finding them....
wraprail is offline   Reply With Quote
Old 04-19-2013, 12:38 AM   #49
JellyBeanDriver
No luck at mine - tried there first.
