Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-16-2010, 01:50 PM   #26
Bad70sbchevy
Bad70sbchevy's Avatar
Re: Compression Ratios
So there's no generic rule of thumb for compression ratios to run on pump gas since it depends on dynamic compression, spark plug location, longest flame path, cylinder head material and design etc...
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 09-16-2010, 01:59 PM   #27
pockets
pockets's Avatar
Originally Posted by Super73 View Post
you can have a 10-1 motor that requires race gas.. Again, it's not all about static compression ratio..
sure, but it is pretty rare, short of a supercharger, nitrous, etc.
Project Bad Karma
pockets is offline   Reply With Quote
Old 09-25-2010, 01:52 PM   #28
jrcaprai
this might be easier... think of Cylinder pressure... you could have a 10:1 engine with a mild Cam 208/214° Deg @.50 and have a Cylinder pressure of approaching 200 psi, now you can have that same 10:1 compression ratio, and have a cam of 242/248° deg@.50... now that cylinder pressure is around 150 psi, due to the overlap bleeding the Cylinder pressure off... high cylinder pressures are the cause of Detonation, not Compression Ratio all by itself... also you can drop timing a few degrees and run an 11:1 engine on 91 octane, then when you go to the Track, bump up the timing and run Race Gas for full power.
My engine is a 11.6:1 408 sbc... Flat top pistons, 64cc chamber, zero deck block, and my cam is 242/248 @.50 and I run 91 octane on the street with 30° timing, because my cam bleeds off cylinder Pressure...
Reversion only happens at lower RPM's, once you get a above about 4000 RPM Reversion goes away because the air is moving too fast...
jrcaprai is offline   Reply With Quote
