09-11-2010, 09:12 AM | #26 |
Re: What sealant to use on differential housing?
Here's the GM p/n for the factory 12-bolt differential cover gasket:
15634848 [Assuming you can still get them.]
09-11-2010, 10:58 AM | #27 |
Between Trucks...
I'd use a gasket if I could as well. Does the top one in the link look right?
http://www.napaonline.com/Search/Res...+50014+2014024
Beat it to fit, Paint it to match... |
09-12-2010, 08:53 PM | #28 |
NAPA's p/n .~...13391 looks closest. The "tell" is the 12 bolt holes. It would be easier to eyeball if they displayed the gaskets in the orientation they work in, not symmetricaly vertical, but to someone laying out a catalog [who's probably never even changed their own oil] I guess it made sense. In real life, the "fat side" is on the drivers side.
Oh yeah, in regard to the original question, I am going to use RTV Ultra Blue, since it's supposed to be oil-proof.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-12-2010 at 08:56 PM. |
09-17-2010, 10:52 PM | #29 |
I done some slight work on the pan (one small ding) after cleaning. Installed a gasket (none used before) used some black RTV designed for differentials (so it said on the package). Refilled after a rattle can on the cover in a light silver so I can keep an eye on it. I'll spray it back black after a while. Car show tomorrow see how it acts. Thanks for everyones input..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-18-2010, 09:56 AM | #30 | |
09-19-2010, 06:47 AM | #31 |
That's good stuff. I use it on both sides of the L6 header/intake gasket.
