#26 |
![]() Join Date: Jan 2010
Re: parting out a 68 lwb 4wd 4 speed truck.
Looking for striaght dump exhaust manifolds. Shipping to 08527
Thanks,Don |
#27 |
![]() pic. of rear end with cover off. hoss wish you were closer. steve i will look frame over and get a pic. of cross member if all is good hows $200.00 for frame and eng x member sound?
i have 67/72 chevy truck parts f/s. |
#28 |
don i have 1 or 2 straight dump manifolds but both would be right side. the ones i got with this truck dump in back i will try to post a pic.
#29 |
![]() tony here is rust on pass. side fender.
#30 |
![]() these are the manifolds that came with it.
#31 |
sounds good, let me know, the crossmember would be the main deal if it is the angled one.
Thanks, Steve |
#32 |
![]() steve here it is the frame looks pertty much like this pic. everywhere . if you are still interested in it i will look it over closer.
#33 |
bguild $65.00 shipped for everything except fender elms. they are pealing.
#34 |
Bill, would you have the rear u-bolts and plates? Need it for a 723 1/2 ton 4x4 rear.
#35 |
67gmcstepside i may have some already off i will get you a pic. sunday afternoon.
i have 67/72 chevy truck parts f/s. Last edited by billsbowtie; 09-11-2010 at 09:35 PM. |
#36 |
Thanks for the time, I am going to pass. The crossmember is for the v-8 and 250, the one I could use is the one that is on an angle. I have a full 1/2 4x4 frame that is set up for a burb already. it needs rear frame horns, which i have. i was hoping for the 292 crossmember, thats the one i have to dig out.
Thanks Bill, Steve |
#37 |
ok steve.
#38 |
![]() Join Date: Jul 2009
Bill, how much for the inner fenders, if you will sell them separately?
#39 |
tj if no one buys the hole clip in a few days i will take $100.00 for both inner fenders.
#40 |
Thanks, Let me know if you decide to sell them.
Thanks, Scott |
#41 |
got any pics of the int.
#42 |
Thanks Bill! |
#43 |
Bill the fenders look good, but I am going to pass right now. I am not ready for another road trip to VA right now after buying the blazer this weekend. Thank you very much for your time.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
#44 |
![]() 67gmcstepside do you see anything in the pic. you use?
#45 |
Its to mount a 1/2 ton 12 bolt rear to my 67. Let me check the axle spacing and u-bolt lenghts required tonight when I get home. If these came off a 1/2 ton rear I can use them. I would need the rounded sets and the top plate. If I remember my leafs are 2.5 inches wide so is this the spacing of any of the top plates?
I'll reply when I get home tonight. Thanks for taking the time. I am sure one of those sets should work. Last edited by 67gmcstepside; 09-13-2010 at 07:57 AM. |
#46 |
OK Bill, the top plate needs to be 3 inch's across center hole to hole and the u-bolts need to be 2 3/4 to 3 inchs wide. These measurements should be for 1/2 ton axles.
The lenth of my originals are 8 inchesd but that is for a 3/4 so I assume the lenth should be a liitle less. Looks like you have a few 1/2 ton'ers in the mix. Not sure about the top plates from the pics. Hope this helps. Let me know, Don Last edited by 67gmcstepside; 09-13-2010 at 06:25 PM. |
#47 |
![]() Join Date: Jun 2009
so is the cab sold? if not what condition is it in and how much?
#48 |
PM sent to go pick up trans/case setup..Thanks Bill
#49 |
![]() Join Date: Feb 2010
hows the hood? i need one again!
#50 |
67chevy1series i will try to get some inside pic.s what are you interested in?
don will try to get some measurements for you. gr8-68 i should know something tuesday on the cab. if it don't sale how much of it would you be interested in. just the hull or do you need title,wiring harness,seat,doors. if it don't sale i will give you a price depending on what you need with it. 70blazerx2 see you tomarrow. 72k5zl1 this hood has a dent i do have another 1 but it has a little rust neither are worth shipping . if i missed anyone let me know.
