Old 09-18-2010, 07:11 AM   #26
c10sport
c10sport's Avatar
Re: Score at pick n pull, now need help.
Was looking at this again...Maybe it will bring me luck in finding one at the yards this weekend.
Of course, it would be even better if i could find one of the clusters with tach and electric speedo.....
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 09-18-2010, 08:59 AM   #27
b454rat
You can take a non-tach housing and put a tach in it. I had a bunch of tach clusters and one time, IIRC one was busted to hell, I took the guts out and put in an easy to find non-tach housing. You do need to cut a small hole in the back for the tach leads to go thru, but that's aboot it.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 09-18-2010, 10:16 AM   #28
RandyP
Getting Old; Going Broke
RandyP's Avatar
What'd you do where the little gas gauge mounts? Most are just empty hole areas with no mounting tabs, unless it had a clock in it.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-18-2010, 10:31 AM   #29
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by mcbassin View Post
I thought the housing was the same though?
The area behind the tach is different than a non-tach cluster. He could cut it out and epoxy it into another good housing and transfer the printed circuit board. Similar to what BLE 'BURBAN did with his.
Just can't be a housing that came with a clock as they were different in the lower left corner.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-18-2010, 10:41 AM   #30
68 TT
68 TT's Avatar
The clock area has a different design to it with holes for the clock wiring so no other gauge will fit there due to the lack of spring clip mount area.
A standard housing with nothing in the lower left can be modified to hold a gauge by just epoxying a 3/8" nylon rod into the housing where you need a gauge mount point.
http://www.onlinemetals.com/merchant...19&top_cat=181
Old 09-24-2010, 04:28 AM   #31
BamaDave
Update Posted
BamaDave is offline   Reply With Quote
Old 09-24-2010, 04:32 AM   #32
BamaDave
Guy said it is new in box ACDelco part. These are the ebay pics. The tach area looks different, but I guess we'll see what happens. I got the part cheaper than what I paid for the used tach.
Old 09-24-2010, 04:39 AM   #33
BamaDave
other pics
Old 10-01-2010, 06:33 AM   #34
BamaDave
got the new tach housing in, and it is as advertised! Brand new ACD part! Now I need to see how my 86 speedo will fit, or if it will.
Old 10-01-2010, 11:19 AM   #35
68 TT
68 TT's Avatar
That housing has the hole for the optical VSS lead. Your 86 speedo will fit just fine.
