Old 03-12-2003, 01:09 AM   #26
Jesse 67 c-10
Jesse 67 c-10's Avatar
yup I did the 5 spd, a getrag, from a 90 chev half ton. you don't need a high hump, I have my 327 in the 6 position, its tight but it works. ya the hyd clutch is a pain but works great once its in. I'm gettin used to drivin with no speedo too! hehe, ya I'll have to do something about that eventually. From the truck make sure you get, clutch master, slave, hose, pushrod, clutch arm, flywheel cover, Shifter!, tranny yoke, mount, drain plugs. nab the plugs for the electrical stuff too, you might get an elec speedo sometime. I got a decent price on mine but it was pretty well stripped! that sucks rounding up all sorts of little crap. Also, most newer trannys take a different type of oil too, not just plain old gear lube, the dealer will know. its not expensive. Good luck!
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 03-13-2003, 09:22 PM   #27
gmc67swb
gmc67swb's Avatar
Hey chip327, I have pics of the tranny with the mid shift mounted. I'll probably put it in this weekend. I'll try to get some pictures as I go.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 03-13-2003, 09:26 PM   #28
gmc67swb
gmc67swb's Avatar
pics
if you look at the gold plates, you can see all the possibl shift locations
Old 03-13-2003, 11:10 PM   #29
Lumpy
2 tons of fun
Lumpy's Avatar
Question
Hey gmc67swb,
Is that a tremec 5 speed? I am hoping to get a tremec tko in the near future. Thanks....Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H
Three Rivers, Ca
Pics at: http://www.cardomain.com/id/lumpy454
Lumpy is offline   Reply With Quote
Old 03-14-2003, 03:36 AM   #30
Chip327
Chip327's Avatar
Sweet looking tranny that Tremec. Cant wait to see the installation pictures when you are all done.
CHIP327
67 GMC Pickup
Chip327 is offline   Reply With Quote
Old 03-14-2003, 07:36 PM   #31
gmc67swb
gmc67swb's Avatar
Originally posted by Lumpy
Hey gmc67swb,
YEAH YOU GOT IT RIGHT LUMPY, I'VE BEEN WAITING A LONG TIME FOR THIS ONE. NOW I CAN GET RUBBER LIKE THE SMILEY GUY
