Old 09-14-2010, 03:32 PM   #26
dman1982
dman1982's Avatar
Re: brake/running lights? wtf?????
its not long enough, it looks just long enough to goto the fuse box. but ill check
dman1982 is offline   Reply With Quote
Old 09-14-2010, 03:59 PM   #27
dman1982
dman1982's Avatar
i checked...the brown wire on the switch goes were its suppose to go until it comes down to the fuse box....????? stuck like chuck
Old 09-14-2010, 04:34 PM   #28
fixit-p
fixit-p's Avatar
The brown wire from the switch shouldn't go to the fuse block it is fused before the switch unless you mean the bulk head connector. Check the brown wire you found for continuity to ground if it has continuity insert power to it and see if your lights come on (I would use a power probe here, but you can make a test jumper with an inline 20 amp fuse to insert power) just to identify that wire.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-14-2010, 05:07 PM   #29
dman1982
dman1982's Avatar
now i gotta goto autozone....used the last one on my memory wire for my radio
