#26 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: front coil help
Get a coil spring compressor from your local auto parts store.
They should rent, sell, or loan them.
#27 |
Re: front coil help
i remember having a similar problem..
i used a chain. i hookd it to the jack and then up to the frame and back again to the jack. so as i jacked up the lower control arm, the chain held the rest of the truck from raising up and it held itself inplace and therefore compressing the coil. also put a strap on that coil, cuz that thing can fly outta there and a strap will at least limit to where it flys. be very careful where u hook up the chain on the truck and make sure u dont pinch any brake lines... |
#28 |
yeller
Re: front coil help
If you have a front sway bar, remove it so you can drop the LCA even more, might make the difference for getting the coil in/out. Had to do that on my 77 when I cut my coils.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 09-20-2010 at 12:14 AM. |
#29 | |
yeller
Re: front coil help
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#30 |
Re: front coil help
ok guys so i got a compressor and i did unbolt the sway bar i cant compress the spring enough becuase the shaft on the compressor gets 2 long and it hits the top control arm
#31 |
Re: front coil help
The way I have done it in the passed with my 1 ton front coils is as Datguysal stated.
Put the uncompressed coil in the upper pocket and use a hydraulic floor jack to lift the lower control arm into place. I have done this on two different vehicles, one being my 82 when I rebuilt the whole front end.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#32 | |
Re: front coil help
