#26 |
Re: headlight problems
Wiring diagrams here:
http://www.dartez.com/images/70/diagram1.GIF http://www.dartez.com/images/70/diagram2.GIF Ray |
#27 |
Well I wired around the dimmer switch last night and Tada! So me and my girl took a drive, windows down listening to the purrr of 8cylinders. It was very cool! Thanks guys for all your help, gonna try to pick up a dimmer switch this week.
#28 |
This just happened to mine tonight. I had to leave it parked at a gas station till tomorrow >
#29 |
Gone to greener pastures
![]() Join Date: May 2007
Yep. That's it.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#30 |
Awesome, thanks. I was told when I bought the truck about a month and a half ago that the high beams didn't work. The headlights have been working fine until tonight tho. Could this switch have been shorted out maybe and is also what's been causing my battery to drain every few days?
#31 |
its all about the +6 inches
did anyone consider looking in the electrical forum on this board? There's a real nice schematic in the FAQ over there.
#32 |
Old member
OK,
take the drivers side light out it has both it and the passenger side hooked to it. Turn the lights on and with your test light see if it has power to it. If not start back tracking until you find the problem. I beat it's in the head light connector. The connection behind the head lights has a ground wire to and it's broke I bet you. My daughter eclipse was the same way. Should have read all the post, glad you got it figured out! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 09-24-2010 at 10:26 PM. |
#33 |
I bet this post went unnoticed but all I did was cut off the plug and connect the wires back to the switch with some new spades and voila, a month of headaches just went away and I spent no money
#34 | |
![]() Join Date: Jul 2007
I went through about 3 dimmer switches and who know how many wire connectors on my truck in the past couple of years. 55/100 H4 bulbs. I replaced the dimmer switch and pigtail to the switch with Napa Echlin parts last weekend on mine when I was installing relays for the headlights. |
#35 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's the headlight relay diagram.
You anywhere near I-26 and 78 in North Charleston ?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
