Old 02-28-2011, 10:02 PM   #26
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73/74 grill swap
Originally Posted by c10sport View Post
yes it does. I put a 1973 grille (also my fav, your truck would be my (future) truck's twin if you do it) in my 1978 K10 with an inside hood release.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-28-2011, 10:05 PM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
This topic is now an FAQ- "73/74 grill swap"
Articles-
"Refining Sierra"
Old 02-28-2011, 10:27 PM   #28
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Did it on my 76 too!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 04-30-2011, 03:16 PM   #29
N2TRUX
Happy to be here
N2TRUX's Avatar
Perfect fit. Didn't bind up or hit the grille.
I would really like to know how you did this? I am in the middle of my conversion, and nothing fits. I have all internal latch parts but they are totally different from external latch system.
From what I can tell so far I need to change the center brace to 73-74. This requires an external latch release, as well as the matching core support filler panel, and strike pin.
I have some of each, but thats the best combo I can see that will work.
Old 05-18-2011, 10:55 PM   #30
superwade57
so im going to say this knowing i will sound like a 15 year old school girl, and i understand this will immediately revoke my man-card and all priveledges associated with it- BUT......
OMG OMG OMG!!!!!!!!!!!! I AM SOOOO EXCITED!! LIKE I TOTALLY CANT WAIT!
(shreaks and other high pitched squeeling noises associated with teenage girl excitment also happening)
pics pics pics for kicks if you can find a gmc 73/74 grill you should post pics of it too. but all shreaks aside, its gonna look awesome! please please dont forget the all to commonly over-looked amber colored turn/courtesy lamp lenses. imo they are half of what makes the 73/74 front end look soo bad a**
superwade57 is offline   Reply With Quote
Old 05-18-2011, 11:35 PM   #31
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Not so sure if the support filler needs to be different...
Only things I changed on my 76 were the center support, hood release and outside brackets. All sourced from a 74 GMC.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 05-19-2011, 07:25 AM   #32
RandyP
Getting Old; Going Broke
RandyP's Avatar
Did it on my 79 K5, it had an internal release and I swapped it to the external. I had pieces from a 73 model for the swap. Had to put in the grille brackets, vertical support, lower valance/gravel shield and the radiator support filler panel. The filler panel where the latches bolt on are totally different between internal and external latches, the latches themselves bolt up differently and have different mounting locations.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-19-2011, 08:57 AM   #33
N2TRUX
Happy to be here
N2TRUX's Avatar
I found all this out a bit late in the game. I was under the impression that when the went to internal release that ALL trucks came that way. Now I know that it was optional for several years.
Sooooo, if you have an external release from 75-80 all you need is the center brace and outside brackets. If you have an internal release, you will also need the external style hood latch, strike pin assembly, and core support filler panel.
Yeah, NOW I know.....
Articles-
"Refining Sierra"
Old 05-19-2011, 11:40 AM   #34
RandyP
RandyP's Avatar
I never even looked at the hood pin/striker. We swapped the hood and hinges from my 74 while doing all of this, guess that was lucky on my part. Glad I saved the entire core support from that 73, even though it was totally rusted out on the bottom. I didn't know that top plate was something separate at first. I was really scratching my head trying to do the latch swap at first.
Old 05-19-2011, 12:29 PM   #35
Jonboy
Slots go on anything!
Does it look possible to use an internal release with the 73/74 grille? I have spare internal release parts, but don't have the truck here to compare.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-19-2011, 12:43 PM   #36
RandyP
RandyP's Avatar
The latch would be difficult to install on the 73/74 vertical support, and the 73/74 vertical support would be difficult to install on the core support filler panel made for the internal latch system.... I'm sure it could be done, but you'd be drilling and cutting and probably using a lot of washers.
Old 04-24-2016, 12:55 AM   #37
Hizoot
Hizoot's Avatar
Cool Re: 73/74 grill swap
Just curious Gents,
Could a reverse swap be done, from 74 to 77 ? From what I see it might require the core support sheet metal to be replaced.
Thanks,
Hizoot
Hizoot is offline   Reply With Quote
Old 04-24-2016, 07:46 AM   #38
Willowrun
Willowrun's Avatar
I've swapped to the 73-74 grill at least three times and I feel that the swap to a later style should be no issue as long as you have the correct center and side supports.
Old 04-25-2016, 01:06 AM   #39
Hizoot
Hizoot's Avatar
Thanks,
Guess I'll need to locate those.
Hizoot
Old 07-17-2020, 04:26 PM   #40
BILL7718
Meanwhile, in 2020, this thread helped me to update (downdate?) my 77 c10 to the 73 grille. Plus, I'm adding a NOS blue bowtie to the front which was in another thread on here. It fits perfectly.
https://img.photobucket.com/albums/v...0/IMG_6466.jpg
Last edited by BILL7718; 07-17-2020 at 04:34 PM. Reason: update link to photo... again.
BILL7718 is offline   Reply With Quote
Old 07-17-2020, 06:18 PM   #41
TKCR
TKCR's Avatar
That looks very nice!
Old 07-19-2020, 09:45 AM   #42
jkk
jkk's Avatar
73 grille in my 80 clip
http://67-72chevytrucks.com/vboard/a...1&d=1595166240
http://67-72chevytrucks.com/vboard/a...1&d=1595166285
jkk is offline   Reply With Quote
Old 09-08-2020, 11:41 PM   #43
Chucks72
Chucks72's Avatar
Hello and great post.
If you will not be using the two lateral brackets you had to remove off of your truck i would like to buy them plz.
Message me on Instagram if you can Plz
@Chucksee
Chucks 72 SWB in Miami
Chucks72 is offline   Reply With Quote
