Old 09-28-2010, 02:33 AM   #26
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Odometer
Here's my spare electronic speedo that I pulled apart to reset to "000,000.0" for demonstration purposes only. Mind you that if'n I ever need to put this unit back into use I'll either swap out the odometer with my original one or reset this one yet again to match my current mileage. I don't have any desire to get busted for turning back an odometer on any vehicle to show less miles than what on it from the day it was ORIGINALLY MADE. Federal offence that is. Anywhere. PERIOD.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Start by making note of the speedo needle position. Then, using a fork, slip the tines of the fork under the base of the needle and GENTLY pry it up and off it's shaft.
[IMG][/IMG]
Then the 2(TWO) screws in the face of the gauge and remove the face.
[IMG][/IMG]
Then the retainer clip for the odometer and slide the odometer to the left to release the right side and lift it out.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
On the back side of the odometer you'll see a plastic retainer that may or may not be in good pliable condition remove it VERY CAREFULLY as to not break it. If you do break it you can make a new one out of a thin piece of stiff plastic like the clam-shell packaging of replacement wiper blades using the old retainer as a pattern, an X-ACTO knife, a steady hand & patience.
[IMG][/IMG]
Now you should be able to reset, from left to right, the mileage so that it matches your original miles on your vehicle. reassemble and everything should work without a hitch.
[IMG][/IMG]
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-28-2010, 07:08 AM   #27
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: Odometer
Thanks buddy that explains it pretty well
Stitch is offline   Reply With Quote
Old 09-28-2010, 07:35 AM   #28
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Odometer
Yes it certainly does ,but what i read about the
FEDERAL ODOMETER LAW Motor Vehicle Cost Information Act, 49 U.S.C. Section 32704
1. (It shall be unlawful for a person) "with intent to defraud, operate a motor vehicle on a street, road, or highway if the person knows that the odometer of the vehicle is disconnected or not operating; or
2. The owner of the vehicle or agent of the owner shall attach a written notice to the left door frame of the vehicle specifying the mileage before the service, repair, or replacement and the date of the service, repair, or replacement.
3. A person transferring ownership of a motor vehicle shall give the transferree the following written disclosure
A) Disclosure of the cumulative mileage registered on the odometer,
B) Disclosure that the actual mileage is unknown if the transferror knows that the odometer reading is different from different from the number of miles the vehicle has actually traveled.
(b) Mileage Statement Requirement for Licensing. - (1) A motor vehicle the ownership of which is transferred may not be licensed for use in a State unless the transferee, in submitting an application to a State for the title on which the license will be issued, includes with the application the transferor's title and, if that title contains the space referred to in paragraph (3)(A)(iii) of this subsection, a statement, signed and dated by the transferor, of the mileage disclosure required under subsection (a) of this section
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-28-2010, 08:00 AM   #29
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Odometer
I've only done this when putting in a new engine or tranny.With no intent to defraud .And they imply it's ok if it's disclosed.Oh and i don't sell cars I only buy em.But someone could easly put in a different/lower milage cluster,heck i did that cause the Plainsman was in miles not km
This cluster was one set to 000000 for my 81 lemans,wish it was a clearer pic.this was done in 93.
John
