Old 12-01-2014, 12:27 AM   #26
jtrichard
Re: Anyone put a Turbo 350 behind a TorsionBar 60 Chevy Pickup?
if you don't have side engine mounts now you will have to put them in as well as a rear cross-member...as for the height look where your drive shaft is now going through the X frame now and make sure it is still in the same place with the turbo350 when done
jtrichard is offline   Reply With Quote
Old 12-01-2014, 12:30 AM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I got side engine mounts already installed.
66 C20 Service Truck:
Old 12-01-2014, 01:09 AM   #28
jtrichard
your half way there look at posts 15 through 18 above for the rear cross member they built ...you will need to remove the bell housing cross member you have now and build a rear one and make sure your shaft is in the same place as now.....after that gas, key ,start and gooooo!
Old 12-21-2014, 09:59 PM   #29
Joe Pass
Joe Pass's Avatar
I just saw this thread so I posted a picture of my th350 cross member in my 62 .....Name:  DSCN1594.JPG
Joe Pass is offline   Reply With Quote
Old 12-22-2014, 03:25 PM   #30
doobiebro
doobiebro's Avatar
Although mine is a 700r4 trans I just purchased a universal tube trans mount and cut, fabbed, and welded together and bolted on the side frame rails.. the universal tubed mounts all look the same but diff application for trans..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 10-05-2015, 08:45 PM   #31
LostMy65
LostMy65's Avatar
Originally Posted by Legend56BC View Post
OK the job is finished and I don't want to steal my daughters thunder but here are the finished pic's of the 261 cu/in connected to a Turbo 350 in a 1960 GMC 910 Canadian truck. Oh my daughter has joined here now and she is MissTiffanyKnight and she posted in the new member section.
That brass colored transmission support there where the bellhousing mounts to block looks to be a good add on.
Does anyone know where one like it can be purchased?
Old 10-05-2015, 11:54 PM   #32
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
maybe inliners international?, or speedway motors?
I would say it is purpose built to bolt modern 63 and up trans to the earlier 62 and down inline 6 with the single front mount. if you have a side mount v8 or 6 and went with a tailshaft mount auto trans this extra mount would not be needed.
torsion bars
