11-24-2010, 01:29 AM | #26 |
60-66 Nut
Re: Ordered my new 17 inch smoothies!!!
Was just wondering about you the other day Steve. Glad to see you're still moving forward.
11-29-2010, 01:42 PM | #27 |
tires are here and waiting on rims... cannot wait to get them mounted up.
12-17-2010, 07:02 PM | #28 |
Well they are here!!! Looking good I mounted them up raw to check fitment.
I think I will paint them The burgandy and leave the caps chrome and add a grey stripe. Last edited by GMR-PERFORMANCE; 12-17-2010 at 07:05 PM. |
12-17-2010, 07:18 PM | #29 |
Redneck Hillbilly
Looks good. I like the burgundy paint and chrome cap idea, should be really nice.
12-17-2010, 07:32 PM | #30 |
sample of the color
12-18-2010, 12:02 AM | #31 |
Cool wheels!!...Stockton wheel is just around the corner from where I live.
1966 GMC Current project 1966 Chevy C10 Sold 1985 C10 Sold 1968 El camino Sold 1954 Ford Anglia Sold 1973 GMC Suburban Sold 1974 Chevy C10 Sold |
12-18-2010, 08:31 AM | #32 |
Well , the rear wheels hit the box... that is under stating hugely. With a 3/4 spacer they still hit the inner fender well. So I am f'ckd at this point. I am done with mail order if I cannot touch it bolt it on I dont need it. I went by what they told me would work, as they had built tons of them this way. I explained in great detail to them I did not have the box on the frame so I could not give that spec. Frame specs where given and I was 100% assured they would fit without issue, well have to wait and see till monday to see what they want to do..
I am really getting tired of all of these so called custom made items that should fit with maybe a bit of work.. Custom made = does not fit chit, LOL Trying so hard to get my truck done and and I hit a wall at every step. .. Last edited by GMR-PERFORMANCE; 12-18-2010 at 05:55 PM. |
12-18-2010, 09:36 AM | #33 |
wow that sux.....hope they fix it for ya
_____________________________________ 66 C10 shortbed stepside KEEPER 66 C10 longbed stepside SOLD 69 C10 shortbed stepside SOLD 71 C10 custom deluxe long fleetside SOLD _____________________________________ |
12-18-2010, 09:58 AM | #34 |
Wow glad I know this now I was going to order a set of these for my 64 Panel keep us updated to let us know the outcome...
"If it throws you back in the seat when it shifts, it was slowing down before it shifted" Disturbed Customs 1992 Chevy 1/2 ton 4x4 wore out 350 1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires 1950 Pontiac Chieftain Straight 8/Hydromatic tranny |
12-18-2010, 10:27 AM | #35 |
Senior Car Nut
GMR, how much clearance to the outside do these wheels give you and what year rear end do you currently have? The rears look like 6-bolt, is that correct? As a last resort, if the supplier won't help, you could gain another 3/4 inch per side by scrounging up a late '70 rear (assuming you don't already have the newer, wider rear and you have the trailing arm/coil type), combined with the 3/4 spacers would give you 1.5 each side out from what you have.
Just a thought, I know it's not the ideal solution, which would be for the supplier to fix the problem. I just saw that you have a '62 frame, so the above suggestion is not a straight bolt-in ALTHOUGH some say they've done it without relocating the the perches. Might still be cheaper than getting another set of wheels made up.
Larry Last edited by fleetsidelarry; 12-18-2010 at 11:12 AM. Reason: corrected for year-model application |
12-18-2010, 02:36 PM | #36 |
Better order them today if you want them for the summer show season. . . .....
12-18-2010, 04:41 PM | #37 |
Yellow truck club
can you go with a wider spacer in the rear? I ran a 2.5 spacer on my 59 for 2 years with out any trouble.
Not much weight on the rear to really stress the spacers. I like the look of the rims.....
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
12-18-2010, 05:53 PM | #38 |
Thanks guys I was mad as hell last night.... I spent over a hour with the guy when I ordered the rims. I explained to him what size rim and tire I had how they fit and wanted to stay with the same width , however he suggested moving the rim in some due to the 3/4 inch space I had measured when the box was on from tire to box edge. I followed his suggestion... I know I can get a spacer ..really I think that is BS at this point with 1200+ plus spent on steel rims.
I will call on monday with the measurements on what is going on now. I have a 3/4 spacer( heavy washer type) as a mock up only and it is still lighty hitting and I have 2 1/2 inchs from tire to box edge. SO they would have to replace the wheels really.. On the other hand I found that I lost my thrust bearing on the rear main as well...( longer story on that installer screwed me on the bell housing set up and it was binding uop when the clutch was depressed.. so it forced the crank forward.... thus I had to walk away from the truck for fear on doing something I would have to repair latter.. as well issues with the location of clutch master.. THE hits just keep on coming.. I feel like a flyweight fighter in the ring with a heavy weight.. I would need at least a 1 1/2 spacer to get it located right, so best source for 6 bolt spacer if some one has a part # that would be even better.. I thought I had the size on the rear studs and what the spacing was but if some knows that as well cannot hurt to get info from people that dont have there hand in my wallet GOTTA keep my chin up and move forward.. Last edited by GMR-PERFORMANCE; 12-18-2010 at 06:00 PM. |
12-18-2010, 06:12 PM | #39 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-18-2010 at 06:14 PM. |
12-19-2010, 01:18 PM | #40 |
Well maybe if you are that close you can go down and thump someone if the need comes up LOL .. I have no idea what they will or will not do yet. I have hope they will take care of it ..
12-19-2010, 07:28 PM | #41 |
damn, that blows.
I have heard danger of running spacers but, good things about adapters, much safer. Plus you can space 1-2+ inches. http://adaptitusa.com/5-lugto5-lugadapters.aspx or http://www.wheeladapter.com/wheel_adapters.php
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
12-20-2010, 12:32 PM | #42 |
Well I just got off the phone with the owner of Stockton and they will alter the wheels for free, no issues in fact he was so quick to state they would fix them I was shocked. I was gearing up for a fight, and there was no reason at all. I told him what they where where they hit and that was it.. Box them up send them back we will cut them on the lather move them re weld , reblast and ship them back all for N/C
So for this size tire and my truck the 4 inch back spacing is what I need. So that has me smiling again... I will keep every up to date.. HE said it was a day job so time will tell how long a day really is at Stockton HA HA , all good even if it takes a weeks, not running adapters is well worth the wait. |
12-20-2010, 02:20 PM | #43 |
I looked back but didn't see this info.... what width are these?
12-20-2010, 02:31 PM | #44 |
they are 8 up front and 9 in the rear, so a 275 is flush with the rim edge or extremely close, lets say this drop the rim and tire and the rim will smack the ground.. so there is little issue with the tire being at fault what so ever.
12-20-2010, 03:24 PM | #45 |
OE 15x8 truck ralleys have 4" BS (as does the old Kelsey Hayes solid style steelies). I would have said 4.5" BS for a 9" wheel & OE width 63-70 12-bolt. This would theoretically split the difference on the width change w/o interfering.
The 4" BS should work w/your proposed drop amount.
12-20-2010, 03:48 PM | #46 |
You are correct with a 4 inch rear drop that box side is way down on the tire... I did tell them amount of front and rear drop as well.. WIth a 8 inch vs a 9 you are really only dealing with 1/2 inch on either side so at the end of the day 4 -4.5 would work. Myself would rather have to deal with maybe a bit of trimming or rolling the fender lip than trying to deal with the edge of the inner fender wheel.
Being that the stock gm 78 rim I had a 275 60 15 on it fit great and was well balanced from inner vs the outer I will go with teh stock back spacing . The stock rim is 1.5 on either side so it really is a great fit , you could go a bit in further, but with this short of a tire I do not see that there will be much if any tire wall deflection. Last edited by GMR-PERFORMANCE; 12-20-2010 at 03:52 PM. |
12-20-2010, 09:15 PM | #47 |
here are 15 pages of bad results. please keep us posted.
http://www.jalopyjournal.com/forum/s...d.php?t=182382 |
12-20-2010, 11:28 PM | #48 |
I read through all those complaints on the HAMB but ordered wheels from Stockton Wheel Co. anyway.
Why? Because all of the other 'choices' for steel wheels won't/don't build what I wanted. My experience was exactly as many described. They (it was actually 'Frank' that took my order) explained 'custom built wheels' have a 4-6 week lead time to ship. At the end of week 6, I start calling for progress updates. "Our computers are down, the 'guy' building them is on vacation, they're being built now, they're going to be started first thing next week, they're going out tomorrow", etc.... all the same excuses as posted starting back in 07 on that thread. The most frustrating excuse when I called for my weekly update on Friday afternoons? "They're on the machine & he's almost finished". Why is that frustrating? I received the same excuse consecutive weeks in a row. My order was for 2 wheels . . ..... But, I knew of this probability going into it. I ordered my wheels the first week of January 2010; I received them in April less than a week after they actually shipped. I'm glad I planned for the delay & I wouldn't recommend them to anyone that has a schedule. I know delays are inevitable sometimes when out-sourcing painting, PC-ing, or chroming. Mine were bare steel & I was told they stock the rim hoops in house when I inquired about ordering. Beyond the lengthy wait, I would not recommend them because of the continually frustrating 'excuses'. They were helpful & forthright until they were paid. Beyond that? Not so much. Quality of the wheel? Moderate to excellent depending on your level of expectation. The wheels did have gouge marks in them so they're definitely not for a show car build w/o serious body-working. But, they were 'true' & painted up good enough for me to roll with.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-20-2010 at 11:32 PM. |
12-21-2010, 10:46 AM | #49 |
Well I ordered mine in raw so pretty basic, mine have no large marks int he steel a few small things, but I for one wanted steel , as they look "correct" for that year and style.. I am not a huge billet fan... I deal with it on the Harley's all day every day... hardened aluminum ha ha that my friends is a oxymoron.. Example 600 dollar PM rear sprocket, it last less than 8 pulls on the super charged bike we are tuning. bike only made 184 hp at this point at 14 lbs boost. Missing teeth, worn out in that time.
Steel takes a beating and keeps on going. I hope they bust this job out , Scoti if you live by them, did you stop in and ask WTF on the time line?? |
12-21-2010, 11:15 AM | #50 | |
