10-05-2010, 07:36 PM | #26 |
Re: layed out 67 swb project M.A.C.
I agree with everyone else, an amazing build man! Thanks for sharing the process with us!
10-05-2010, 08:56 PM | #27 |
Nice Build. Other than the bags and the Z, are you running drop spindles to lower the front
10-05-2010, 10:04 PM | #28 |
Very nice work, but I didn't see any link to limit lateral movement of the rear axel. Did I miss it?
10-05-2010, 10:17 PM | #29 |
Did I miss it? What is the name of your green color?
10-05-2010, 10:24 PM | #30 |
LOVE IT! This pretty much is what is in my head for my truck.
10-05-2010, 11:01 PM | #31 |
Very Nice build! congrats!
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
10-05-2010, 11:42 PM | #32 |
ya I am running drop spindles i bought on ebay... Although with small diameter wheel and tire setup and the large z and bags, (with the removal of the bump stops), they may not be necessary... i think the thing would still lay out with stock spindles in my case.. if i was to do it again I wouldnt z it as much and run spindles for sure.
10-05-2010, 11:46 PM | #33 |
With the giant width tabs and bushings oppose to hiem joints on my traingulated upper link there is now lateral movement possible. In addition each of the lower links have equivalent bushing setups both on the front x member and on the rear end...
10-05-2010, 11:49 PM | #34 |
I dont actually have a name.. I was painting some cell tower pieces for a company that were disguised as lamp posts and they brought us a color chip. Our local paint supplier did a prophet scan on the chip and custom created the color. I really liked it so I had more made and used it on both my motorcycle and truck... Id probably call it an olive green or something, and the off white color is simply called "buff"
10-06-2010, 12:25 PM | #35 |
What are you doing for driveshaft clearance? Is the cab floor modified for a driveshaft?
10-06-2010, 12:47 PM | #36 |
Very nice work every part of the truck wow great job!!!!!!!!!
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project) It's your ride build it the way you want !!!!!!!!!! |
10-06-2010, 12:48 PM | #37 |
Junior Member
Nice work man! Chevelle is sick too.
10-06-2010, 01:25 PM | #38 |
I wish I had a better picture.. I will try and take one soon. It is a two piece driveline with a slip joint and a carrier underneath the cab towards the back but pretty much hidden if you look from the bed opening. No cab modification necessary. the carrier is a stock style out of a parts truck that has been attached to a custom tube cross member that bolts between the frame rails. I hope this helps, let me know if you have anymore questions.
10-06-2010, 01:29 PM | #39 |
Moderator
You need to change your user name to "McBaddestasstruckever" or something modest like "McTruckoftheyear".
Seriously cool build, you have real talent.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
10-06-2010, 01:35 PM | #40 |
How long did this build take you?
10-06-2010, 01:52 PM | #41 |
Started the project beginning of January.. worked on it every extra minute I had between then and August when it made its maiden voyage.. since then its been worked on here and there. keep in mind I have a more than full time position running a body shop. But it kept me out of trouble for the most part these last several months. Also drained both me and my bank account lol. totally worth it with all these great comments though!
10-06-2010, 04:33 PM | #42 |
Can you post up some specs for the wheels and tires you are running? They look perfect for this style of build.
10-06-2010, 07:18 PM | #43 |
10-06-2010, 10:52 PM | #44 |
AWESOME BUILD! This is one of the best looking trucks i have seen. Great work.
10-06-2010, 10:59 PM | #45 |
Kvn1011
that is nice!! Really really nice!! do you have a pic of your rear airtank set up??
or even video of your canti set up!! i have a york compressor also, hopefully i can do something close to what you have done!! awesome truck bro!! |
10-06-2010, 11:19 PM | #46 |
Wide n'Low
Sweet looking truck!!
Hope you get up to the Portland Vancouver area so we can get a close up view. Very nice work..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
10-07-2010, 12:22 AM | #47 |
What was I thinking?
SICK!!!!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
10-07-2010, 12:54 AM | #48 |
The back half of my frame is air tight and is the air tank... I have a fitting welded in the inside of the frame rail behind the rear cross member i think some of the pictures in my thread show it
10-07-2010, 02:23 AM | #49 |
AMBITION
bro i love this truck honestly its my fav one on this forum i look up to this truck and wat u did to it!!! im going with that same look on my truck too the all original slammed look!
10-07-2010, 11:10 PM | #50 |
Old school original look is where it's at!
Posted via Mobile Device |
