#26 |
God is good!
Re: Got a little done today....
I always use PB Blaster as opposed to WD. The best way to get stubborn bolts off without causing damage is with a breaker bar, preferably 1/2 inch drive. Huge difference in leverage.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
#27 |
PB BLASTER + 1/2 breaker bar (and maybe use your legs, instead of arms) will loosen anything!
#28 |
![]() Join Date: Dec 2008
#29 |
Seems like the majority vote....I'll try that when I can...and I just went through your build thread...(sorry I haven't checked it in a while) and I think you should go with that bigger motor in his memory.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
#30 |
breaker bar and a pipe to extend the handle to increase leverage those torq heads are strong and you'll break the socket before you strip the bolt head. If you can get your hands on some Kroil it will make pb blaster seems like junk. We use it at work it creeps into gaps supposedly one millionth of an inch or so it says on the can. Whatever it says it works AWSOME! Oh and if you can after you spray oil around the bolt head just hit the head a few times with a hammer help the oil get in not crazy swinging, but just a few taps. sounds dumb but it'll help with the gap between threads.
Nice truck by the way! |
#31 |
I got my new dual cowl hood in from LMC truck today.....I got a new true dual exhaust system two days ago but I don't have any pictures of it yet....here are just a few pics of the new hood....the first picture is of the actual cowl part....fully functional
#32 |
![]() Join Date: Apr 2009
i like alot
#33 |
dat cowl hood is so frickin sweettttttttttttttttttttttttttttttttttttttttt
#34 |
o i for got its fully functional to
#35 |
Thanks! (above) yeah, I just had to add the fully functional thing just so everyone would know it's a REAL cowl hood
#36 |
Got my new hinges/ springs and brace kit from LMC today. I was going to just get a good pair of used hinges but I have a friend in the auto body business (who just happens to own a 70 Chevelle) and when I talked to him about helping me line the hood up he said that I defiantly shouldn't get used hinges on a new hood. So I went ahead and got new everything + a brace kit because it's kinda like cheap insurance......and It doesn't matter (to me) if it looks a little bad on the backside of the hood because I don't plan on showing it or anything. I hope to get the hood on Friday with my buddy but if he can't I probably won't get it on until late next week due to a trip to Austin this weekend.
#37 |
keep pluggin away at it...
my truck had similar issues getting it reliably driveable.. . - alot of gaskets on the motor to keep it from leaking all over - tuneups, rad /heater hoses- stuff to make it reliable! - recon rad - all new brakes little by little as everyone says... the nice thing is- parts are cheep for our squares! mine (an 81) turned antique this year! cool to drive an antique thats reliable with power steering , brakes, ac and good jams! |
#38 |
Sorry guys...no new hood to show you
#39 |
Went to go start up the truck tonight and took a minute for it to start...it turned over a little and then I tried again only this time instead of turning it just made a low "errrrr" noise for a second so I let off and then tried one more time and it started right up? Anyone know what that noise might have been? Well in the mist of doing that I kinda looked at the decaying dash pad and decided....I'm free tonight...I'll just yank it out.....came out pretty easy cept the left side was baked onto the metal dash and required a little force to break it away....also noticed that there were glass pieces all over the dash under the pad...I guess the windshield was knocked out once or so? Anyway I found out that about half of the clips were just gone...you could see where they were so I figured they might have fallen off but they were just gone.....couldn't find them...also found some plastic crap around the plug in for the "in glass" antennae....don't know what it's for so I left it alone but it was really hard to try to pry off without scratching the windshield with a knife or something.
#40 |
Got the cowl hood on today...and it looks GREAT!!!
![]() only problem I ran into is the mounts for the wiper fluid shooter things at the back of the hood(sorry don't know what they are called exactly) there is a hole for the first screw but none for the second and since the hood doesn't have the grills like the last one it's rather hard to mount them...oh well I'll get those hooked up and finished another day
#41 |
![]() Join Date: Jul 2010
that hood looks nice
#42 |
thanks, I got the hood from LMC and it's good quality except one of the bolt holes (pass. rear) didn't want to line up very well and there were a few burs on the ends (I found that out with my fingers
#43 |
Well had a lot of free time today so I worked on the old truck....where to start, I knew that the brakes were a big problem so after letting it sit for a while checked the brake fluid to confirm there was a leak...well there wasn't so I went ahead and bled the brakes and now they work like it was factory fresh...maybe a little touchy, I decided to pain the roof of the inside cab for a little starter for the inside paint...and to get in a little practice...thought it came out okay....I fixed the idling problem by putting in new return springs since the old ones basically when stretched, stay stretched.....took apart air cleaner to find out that since I bought the truck last August that I wasn't running any air filter (who's dumb idea was that?) should have checked that earlier...and found out I have a two barrel carb instead of a 4 that I thought I had
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 Last edited by THE "10" SILVERADO; 02-28-2011 at 01:36 AM. |
#44 |
and more pictures...
#45 | |
GoatLube Experss
![]() Join Date: Oct 2009
your truck is come'n along nice, the hood really made a differance. look's good!
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#46 |
Just got a few parts on today...got a gas gauge, printed circuit and new review mirror...I just need my speedometer and then I can do my full gauge/circuit swap at once so I don't have to keep taking it apart to replace everything....and when it's done I can finally rely on my gauges.....the mirror was one of LMC's reproduction mirrors and for the most part it looks like a factory one....but a little better IMO
#47 |
truck is looking sweet! keep up the hard work!
#48 |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#49 |
Haha thanks! also thanks Big10Charlie...small update I guess...got more parts in.....waiting for my instrument lens that is on backorder to complete my instrument cluster...and got my dash pad, going to salvage yard soon to pick up a square fuel hole bedside and new "sport" rear bumper....also basically finished the interior painting...just a little touch ups here and there
#50 |
Oh yeah, forgot to say that I picked up a tilt column from a 79....going to send it to a company nearby to be rebuilt and rewired....also considering a EZ wiring harness to switch to blades and to replace the hacked wires I have...
I have one wire that's supposed to be yellow (I think) and I goes from yellow, to blue, to purple, to blue again, and then back to yellow.......fun...
