Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-25-2010, 11:06 PM   #26
dbmx66
Re: crank case evacuation? help
Originally Posted by 69trk View Post
would this evac system help keep my nitrous big block plugs cleaner? Right now all i have is breathers. Also, will it help with oil loss...
good question. anyone?
dbmx66 is offline   Reply With Quote
Old 10-25-2010, 11:41 PM   #27
nxtruck
nxtruck's Avatar
OK; when you say "cleaner", what exactly do your plugs look like? What are you trying to keep off of them? As far as oil loss goes, I can tell you that my system has helped with a rear oil pan leak that I previously removed the engine to fix and still couldn't fix completely.
If you trying to keep cold plugs from carbon-fouling with one of these setups, then this isn't going to do anything for you.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 10-26-2010, 06:41 AM   #28
69trk
69trk's Avatar
My engine is set up to handle up to a 400 shot. It has childs & albert rings, and my engine is burning some oil, but you can't see it. It's leaking a little bit around the valve covers. The plugs always have some oil around the threads and i was told if i had an evac. it would help the rings seal better..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 10-26-2010, 11:17 PM   #29
Rodms
Rodms's Avatar
Its going to relieve some of the crankcase pressure so you can figure that first time I cranked mine under the hood the dipstick hit me in the belly at 11 to1,I have the mrro system and they are cut in right behind the tubes to collector,I would like to know how it works on exhaust if you put it on.I hope you get it and it works!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 10-26-2010, 11:53 PM   #30
nxtruck
nxtruck's Avatar
I don't know how much an evac system will actually help with ring seal, but if this is what you trying to accomplish, I'd probably be looking at a vacuum pump. I know that a functioning evac setup is better than breathers in the valve covers, but I'm not sure how much good 5 or so inches of vacuum really is in helping with ring seal. If you're using light tension oil rings, then I suppose you might see some benefit with the evac and oil usage. But, if you're using std. tension oil rings, then I don't think you'll see much difference.
You should see some improvement with the oil leaks if the system is working correctly.
Off the subject, how much gain have you seen with the 400 shot? Or have you used this much through it?
Chris
Old 10-27-2010, 05:55 AM   #31
69trk
69trk's Avatar
I haven't used any nitrous yet. I'm only going to use 100 shot or so, i want the engine to last me a while....
1.58- 60'
11.37- 1/4 @115.81
