Old 09-05-2018, 03:49 PM   #26
Custom 68
Custom 68's Avatar
Re: rear helper bags
Thanks Andy. Sounds like it worked good. I just didn't know if it needed them to fill the space.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-05-2018, 09:03 PM   #27
Andy4639
Old member
Andy4639's Avatar
Talking Re: rear helper bags
I would use them for the top and bottom so the bag doesn't sit on metal.
I'm telling you my truck rides wonderful with them.
I keep 20 lbs in the front at all times and I'll run 10-20 in the back empty.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-05-2018, 09:16 PM   #28
Custom 68
Custom 68's Avatar
That sounds good Andy. I really didn't know how they would do without much load. Mine does pretty good but I thought it might add a little. I have coil over on the front so I can't use them there. I'm gonna be heading to cruizin the coast in a couple weeks so it will be a good drive. I may give them a shot.
Thanks again
Dave
Dave
Old 09-06-2018, 06:22 PM   #29
draino76
FUJIMO
draino76's Avatar
Thanks for the info. I might have to add this to my to do list.
IF IT DON'T GO--CHROME IT!!
I dont mind confusion, I create it!
draino76 is offline   Reply With Quote
Old 09-16-2018, 05:18 PM   #30
JEC32
I installed the performance online helper bags on my 68 long bed. Install was easy and does exactly what was expected, assists! I recommend highly for the price!
JEC32 is offline   Reply With Quote
Old 09-16-2018, 08:20 PM   #31
draino76
FUJIMO
draino76's Avatar
Do you have a part number for that?
Old 09-18-2018, 12:46 AM   #32
kevmcrae
kevmcrae's Avatar
I put the "inside coil spring" type on my 16 Ram 1500 4wd thinking I could save some money and still get okay capacity. They do okay for lighter trailers/loads. Have the full axle to frame bellow style airbags on my 71 Chev K20 and they are much better for towing heavier trailers/loads. I will likely replace the ones on my Ram next summer with the regular bellows style airbag.
kevmcrae is offline   Reply With Quote
Old 06-12-2020, 12:58 AM   #33
kehstr
kehstr's Avatar
Originally Posted by Mondo View Post
Anybody have this? I'm satisfied with my suspension but want to put something heavier in the bed at times. This seems like a good compromise.
http://www.performanceonline.com/196...DE-ASSIST-KIT/
I have read this thread and no one gives a for sure answer that I saw if these bags work or not. I have used the red bags that go in the coils on other vehicles, but do not think they will give enough lifting for what I haul with my truck.
Has anyone used the Performance Online style on a coil spring truck?? If so can you post pictures?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 06-12-2020, 12:24 PM   #34
kevmcrae
kevmcrae's Avatar
Kehstr, I put "real" bags on my 71 K20. Ride Rite by Firestone makes kits that are easy to install. LMC or similar sell them.
Old 06-12-2020, 06:30 PM   #35
kehstr
kehstr's Avatar
From what I understand, and saw on a quick Google search those are only for a leaf spring truck. Do they make a similar kit for coil spring trucks?
@Chad's Fab
Old 01-05-2021, 07:10 PM   #36
LNP
I Know this has been a while but I was wondering to have any pics if them installed? Thanks
LNP is offline   Reply With Quote
Old 01-09-2021, 12:14 AM   #37
HeavyHauler
I googled Air Lift 60811 and it doesnt say anything about it fitting 1967-1972 Chevy C10?
It looks like the bag would rub with the movement of the coil spring? Also could you show where you routed the air line? Since you had to give them the inside diameter of spring and ride height of truck inside spring. I doubt that the same part number would work for all spring manufacturers even if they are both a 6 in drop spring for example.
Did you have to drill a hole in the frame or the trailing arm to install them. What modifications to the frame or trailing arm were made to install them?
Does it seem to make your truck sway from side to side more when you have air in them?
HeavyHauler is offline   Reply With Quote
Old 01-09-2021, 01:00 PM   #38
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: rear helper bags
Nothing done to frame are springs and trailing arms. I drilled the spacer to let the air line run in at a angle so I didn't have to drill the frame. They now have a kit so they say for these years. When I bought mine they didn't. My truck has the No limit shock relocator kit on the back no swaying, I even took the rear sway bar off of it. My truck handles very well for what it is. It rides great with no bottoming out and mine has no c notch either. It's still sitting in the garage waiting for me to install it.
Old 01-09-2021, 06:27 PM   #39
saxart
saxart's Avatar
I thought the same thing. Here has been my experience.
I installed Airlift bags in the rear coil springs of a 2011 Suburban when it was new. It's now been nearly 10 years since they were installed. The vehicle has 172K on it and there has been zero issue with wear due to rubbing.
We have an 18' trailer that we use occasionally and have towed some massive loads with it with that Suburban. It's not as good at towing as our previous 3/4 ton Suburban, but it makes a HUGE difference to have the bags on this vehicle.
Put it this way, I feel so strongly about the Air-Lift bags that I ordered a set for the '70 C-10 and hope to put them in sometime this winter. Here it is towing a tiny load.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
