#26 |
Ex-Minitrucker
Re: ok geniuses,window tint removal
Always had good luck with any citrus based cleaners. My old job had some called Zone Defense, its an industrial solvent we used to remove all kinds of adhesives just spray it on and wait a few minutes and attack it with a plastic scraper. If you use razor blades you need to bend them a little so they have a slight arch, that way the corners of the blade won't dig in and scratch the glass.
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd Last edited by 68lwb292; 10-17-2010 at 02:52 PM. |
#27 |
one window down,2 to go and thank you guys for all the great responces i will get this done!
#28 |
after peeling tint use rubing alcohol and razor blade what i have used in the past worked perty good, good luck
#29 |
Redefining LowBudget
brake cleaner
#30 |
![]() Join Date: Jan 2008
I used to work in a glass shop doing auto glass, we always peeled it off, then wiped the glue off using Denatured alcohol. It worked like a charm!
