Old 10-19-2010, 04:42 PM   #26
scrapmetalart
Junior Member
Re: Driveshaft concerns/questions
Originally Posted by brad_man_72 View Post
I work in a driveline shop so I build new. You can modify a used shaft. Definitely work for a professional and ballance.
unless you are using a transmission with a bolt on yoke (you can use a slip trans yoke on these transmissions) or use bolt on yoke and have a slip and stub installed at trans end of shaft. The trans yoke provides more than enough slip for suspension travel, and you can't have more than 1 slip in a one piece driveline. It will fall out.
I thought the rear shaft was the problem when lowering & that the slip joint needed added to it....
Maybe the rear shaft just needs shortened after substantial lowering?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 10-20-2010, 01:26 PM   #27
brad_man_72
the boat guy
brad_man_72's Avatar
my last post was only referring to 1 piece driveshafts.
The stock style carrier bearings do allow for some movement fore and aft. If you use a more solid carrier you would have to put a slip in the rear shaft. Carrier bearing refers to 2 piece driveshafts only. Trailing arm trucks usually don't require much slip at all. Which is the only reason can assume gm didn't see the need for a slip in the rear shaft of a 2 piece driveline.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-31-2010, 05:44 PM   #28
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I went to the local drive-line shop and ended up purchasing another carrier bearing for the time being.
He was telling me that that a one-piece drive shaft would need to a large diameter as the skinny ones tend to whip/flex in the middle.
He also explained that the carrier bearing allow the shaft to move back and forth like the slip joint (like mention above). But one problem is when you lower the truck your putting allot of stress on the center bearing.
So I'm going to try to determine how much too long my shaft is and see if it's alright with the current setup.
I'm watching my neighbors house while he's away and I took a peak at his 72 step side. It all original and has a one-piece. Could this be because it's a manual transmission?
Should I just leave a note thanking him for the drive shaft?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
