#26 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: my sorta crew cab short bed build
Ant updates on this one?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#27 |
Update,
i have the two frames, they are at my shop they will be prepped to be cut and welded this weekend. work and family have made it hard for me to make any progress i finally found a short bed 4x4 truck in the paper for cheep, sold the tires and wheels of off it and scrapped the body to make my money back cheep. Finally in getting this show on the road...
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
#28 |
Here's the sb frame, and the burban frame. I've done some measuring and I know where its getting cut. My wife is even getting involved in the clean up. She made sure the new house we moved in to could fit the frame in the garage so she could help me work on it evenings after the kids went to sleep.
#29 |
Sweet! Always great when the wife helps!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#30 |
Update making progress
Finally more progress on this snail build. This has to be the busiest ive ever been when I started this build i was bored out of my mind. Anyhow heres the shortbed frame stripped ready for the MODIFICATION.... ive pulled all the lines and everything. The motor is a 290 hp 350 crate motor with 35000 miles and a gm replacement th700r4 with 35000 miles on it also. heck out the flowmaster exhaust that also came on it. Its keeping a carburetor for now I have a set of L31 Vortec heads screaming for a new home and all im looking for to make it good is the Vortec T.B.I intake manifold. back to the real deal. this prep work is taking for ever all parts removed have been glassbead blasted and wrapped for future paint,chrome, or power coating i haven't decited yet. My wife is still up in the air about what color, she mentioned baby blue i heard Marina Blue and white two tone. Let me know what you think.
#31 |
awesome man keep up the good work!
#32 | |
Re: Update making progress
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#33 |
Yep that is what i was thinking.....
#34 |
well up date time, I got both frames prepped. The motor got swapped today and a set of not my 4:56 axles got put in today with rollers. both are marked and prepped for the cut. I know its taking forever but I'm only able to work on it one day a week from 8am to 3pm, but its well worth the wait. So Im understanding that a LS motor is the prefered. I'm gonna put a carbed motor in it and do the shake down run, 6-9 months of driving to "work out the bugs" then its going to be motor swap time. so heres some pics of the work today. look at the 2wd steering box, for crossover steering. the pickup frame got the rear axle and the burb frame got the front axle. i'm going to rebuild the axles and plan on doing a complete write up on the rebuild im going to go with 4:88 gears with 35's i think. but hopefully next sunday will be the weld it up time. Now lets go look for a np241 with a cable speedometer.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd Last edited by BIG V; 09-19-2011 at 12:04 AM. Reason: more information |
#35 |
I would like some advice..... 5.9 cummings, duramax , 6.5 turbo diesel , or the 350 crate motor?
#36 |
Happy to be here
![]() Join Date: Mar 2000
Since its a 4wd I would go with the 6.5 TD
#37 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Cummins 12 valve is the way to go. No computer to deal with, one million times more reliable and about the same amount of power potential. The 6.5 is OK, but doesnt hold a candle to the Cummins.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#38 |
well today was the cut day. it was cut and welded today there is a fishplate to be added to each side and some minor clean up. there was a couple hurdles that had to be cleared but all in all I would do it again. Next is putting the blazer 30 gallon tank in the back of this frame. I plan on relocating the shocks to under the bed behind the axle. I'm going to smooth the frame rails where the shocks went.
#39 |
Ok, so I'm confused. I'm planning on a Crew cab short bed dually, static drop & a supercharged 5.3. I thought I just shortened the frame 14 inches behind cab and 6 in back. So I don't understand the need to join the frames together. Also how do you make the dually short bed, since they never made one? Can you just take any 73-87 short bed and slap the dually fenders on there?
Posted via Mobile Device |
#40 |
Nice work! That's a nice Cutlass in the back round!
#41 |
Yea the Cutlass has a blown 406 smallblock in it, all Hotchkis under it it runs good too
#42 |
That is freaking sweet! Very nice man!
#43 | |
A dually bed is just a fleet side bed with a bigger wheel well opening and holes in it for the dually fenders to attach to. To make a short bed dually you just cue the openingto match the inner wheel tub and drill the holes as needed.
#44 |
thanks for the explanation on what i'm doing i didn't even see that post. I thought it was 18 behind the cab.
I'm building this like this because I refuse to let the bank give me a loan for 35000 for the truck i want so instead i'm going to build it for less than 10,000. I have mostly everything to build it at this point I have 300 in it not including my time.
#45 |
Finally gonna have time to work on this again. lets talk powertrain. diesel or gas? I've stayed up nights thinking about this, what motor to run Diesel or Gas? I was watching another build where a 7.3 powerstroke is going in to a chevy.... I want to try it too I think.
#46 |
That guy is doing a 7.3 non powerstroke. A powerstroke will be a PITA due to all the wiring. I say diesel either way.
#47 |
Still have the dually wheels? For sale?
#48 |
PITA tells me its right up my alley. so the wiring is going to be fun i love a challenge. now who makes some funny adapters from a ford trans to a chevy tcase?
#49 | |
#50 |
Why not a cummins? Seems like alot easier and cheaper swap. Are you still planning on keeping this 2wd?
