Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-11-2012, 01:38 PM   #26
tolly4503
Re: harbor frieght blasting cabinet?
I live 15 minutes from TP tools, like everyone else said you can't go wrong with them for parts and service.
tolly4503 is offline   Reply With Quote
Old 01-12-2012, 02:27 AM   #27
Mike Bradbury
Mike Bradbury's Avatar
I use an 80 gallon Ingersoll Rand. Tried it with a small 5 gallon home model and it was ridiculous how fast the pressure would drop to the point of unusable. Most important is run a dryer or in line water trap, no matter how good your compressor, if you have wet media it won't work well.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 01-12-2012, 04:07 PM   #28
NONHOG
NONHOG's Avatar
I've got an older version of this....http://www.tptools.com/p/432,367_780...t-Cabinet.html
side load, It needs sealed and more light. I added a cheapo lamp inside and it helps a bit but its always a fight to see when your blasting.
to do it over I'd build one myself or maybe mod a HF. Not that mine is bad.
I'm just cheap.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-14-2012, 05:21 AM   #29
k5xjfiles
Junior Member
k5xjfiles's Avatar
Check out the Barrel Blaster. I just got one and like it. Made in TX.
Paid about $299. I use it with my shop vac. and run it with an 80 gal used Snap On compressor I got off of CL in NC.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 01-31-2012, 08:57 PM   #30
allaboutchevelles
allaboutchevelles's Avatar
heres my homemade sandblast cabinet. works very well. I have probally around 50 dollars in it. I just put in bigger arm holes. was using the 4 inch tollit bowl flanges.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 01-31-2012, 09:35 PM   #31
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Very nice!
Could you provide a parts list and steps to making such a blasting cabinet.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-31-2012, 09:56 PM   #32
allaboutchevelles
Originally Posted by Tri5Nerd View Post
Very nice!
Tri5
55 gallon barrel with removable lid and quick locking band.
replacement blast cabinet gloves from ebay.
cheap work light from harbor freight.
2 peices of 5 inch pipe for arm holes.
siphon feed blast nozzle from tractor supply.
scrap 2x4s to make a frame for the glass. I used a table saw to cut the boards at an agle and made a cut to slide the glass into. local glass shop cut a peice of glass to the size I needed for like 8 dollars.
make a stand to mount it on.
I use my big craftsman shop vac in the hole on the lid and it sucks all the dust out of the barrell, just remember to clean the filter often. Also cut a hole on the opposite side of the barrel to pull fresh air in.
