10-24-2010, 12:05 AM | #26 |
Re: what kind of crap rearend work is this?
I completely agree with low life 99 it looks to me as if someone for some reason decided to weld on the track bar I would just order a new one from cpp. and as far as being the wrong rear end it appears to me to be correct for the truck
10-24-2010, 12:22 AM | #27 |
Looks like some of my early middle of the night manure truck repair welds from 12 years ago.
Outside of the ugly welds, the bracket on the rear end has the bolt/bushing aimed in the wrong direction. They should have come out with a bracket and had the bolt parallel to the ground so that that bushing would actually work when the suspension worked instead of bind like it does now. Unless you just happen to have the correct rear end sitting around in good shape I'd clean things up, make sure that the welds on the spring pads were good and fit a new panhard rod that actually would work right. The truck wasn't converted to 5 lug was it? That could be the reason for the rear end swap. Last edited by mr48chev; 10-24-2010 at 12:26 AM. |
10-24-2010, 03:29 AM | #28 |
Big Red - Now its a SWB!
That was the first thing I noticed, how is it supposed to articulate when it is facing the wrong direction?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-24-2010, 08:32 AM | #29 | ||
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
10-24-2010, 05:12 PM | #30 |
There were chevys with the leaf rears too.
10-25-2010, 09:57 PM | #31 | |
Ray |
04-20-2011, 10:52 PM | #32 |
Grandpa in the rustmobile...
You ever get this fixed or you still trying to get rid of the wife
Anxious to see it on the road semi safe at least
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-17-2011, 10:33 PM | #33 |
Cruzin
Update Okay finally time to tackle this got the rear dropped today and took some pics, also got me some new drop springs and a super trac bar from ECE ready to go.
08-17-2011, 10:36 PM | #34 |
Cruzin
More pics.......need to spend some time under here cleaning and sprayin a little paint and some new bushings for the trailing arms while i'm here.
08-17-2011, 10:48 PM | #35 |
Gonna redo the trailing arm perches aswell I hope?....
08-17-2011, 10:55 PM | #36 |
Cruzin
when i get it all cleaned up i'll see what i have and will do accordingly
08-17-2011, 11:25 PM | #37 | |
edit: just now saw the pics above, DAMN! look at the size of that errr bead! props for it holding together this long - as long as they got the metal to mesh well, it's actually pretty strong
project: "my happy mess" Last edited by litew8; 08-17-2011 at 11:38 PM. |
08-18-2011, 12:51 AM | #38 |
My Carbon Footprint
oh my
08-18-2011, 11:14 AM | #39 |
SWEEEEEEEEEEET welds on that rear end. Either that or you have some big seagulls. The positioning of the panhard rod and its bushing alignment is one for the special mods by PO book.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
08-18-2011, 11:19 AM | #40 |
My Carbon Footprint
I'm wondering if the guy was going for his underwater welding cert on this bad boy.
09-22-2011, 08:55 PM | #41 |
Cruzin
take a look now all fixed up, got to finish painting it. Got to get the truck aligned (installed new ball joints, tie rods etc..) then hopefully drive it some before winter gets here. Replaced brake lines too with pre-made ones for now better than what i had and 4in drop springs, and super trac bar from ECE maybe some shock relocateing in the future. Safer now.
09-22-2011, 10:20 PM | #42 |
Junior Member
Great job.
Sure looks a lot better!
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-22-2011, 10:34 PM | #43 |
My Carbon Footprint
Waaaay tooooo gooooo!
09-22-2011, 10:36 PM | #44 |
looks great nate, you can do a DIY shock relocation scotti wrote one up awhile back.
it gonna be able to make it to lynchburg? you'll need the wipers in this weather!
09-23-2011, 12:01 AM | #45 |
project: "my happy mess" |
09-23-2011, 12:43 AM | #46 |
Lot safer to
1969 Chevy c20(Miss Hackjob) |
09-23-2011, 06:19 AM | #47 |
Cruzin
thanks all i'm glad thats done
09-25-2011, 03:36 AM | #48 |
Lookin good!
