Old 10-28-2010, 09:27 AM   #26
Lee H
Lee H's Avatar
Re: Losing coolant
You'll need to measure the temp with an IR gun or some other device. Everyones feel is different, scalding to you may be warm to someone else. Don't trust the gage until you verify "normal" for your truck. Keep you eye on the level for several heat cycles. If it's continues to eat coolant further diagnostics will be necessary.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 05-21-2013, 11:54 PM   #27
GuyO
GuyO's Avatar
Re: Losing coolant
I had a similar problem years ago. After replacing the water pump, hoses, thermostat. Turned out to be a bad cap. I still have the "new" one I replaced the bad one with 30 years ago.
GuyO is offline   Reply With Quote
