Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Closed Thread
Old 11-04-2010, 05:50 AM   #26
Number21
Number21's Avatar
Re: pvc to plumb air compressor?
Originally Posted by bosephus View Post
I'll bet that they can't pick up PVC shrapnel with an x-ray.
Exactly. It's only a matter of time before there's a picture floating around the interweb with some guy who has a giant peice of PVC sticking out of his eye ball. Do you want to be that guy?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline
Old 11-04-2010, 09:32 AM   #27
motornut
78K & 79C Jimmys
motornut's Avatar
i've only seen copper used in properly set up shops,can't believe someone uses pvc.
heck wallmart sold the red 60 foot hose for under $20. a few years back,
bought a few now i have almost 300 feet of red hose on a reel on the wall.plus a wind up 50 feet and a few of the coily hoses.....gets me there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline
Old 11-05-2010, 10:43 AM   #28
electrician42
electrician42's Avatar
well i'm going with 3/4 copper around walls to the drop's and hose reel's... thanks for all the input.. plus copper looks a lil more professional too ....
2011 silverado 2500hd ext. cab 6.0
2007 tahoe lt
2004 harley-davidson superglide
1982 chevrolet c10 stepside 2 wheeldrive..current project
electrician42 is offline
Old 11-05-2010, 12:38 PM   #29
stich626
whats cheaper now..
copper or black iron
stich626 is offline
Old 11-07-2010, 02:16 AM   #30
Captainfab
60-66 Nut
There's a certain grade of copper pipe that should be used for air lines. IIRC it is type L or something....I don't remember for sure. I'll check on it and post back.
Captainfab is offline
Old 11-07-2010, 02:53 AM   #31
Captainfab
60-66 Nut
OK I found the thread I was thinking about on another forum about running air lines. The copper pies to use is either type 'L' or type 'K' with K being the heaviest wall. Here's a link to the thread......
http://www.offroadfabnet.com/forums/...t=copper+lines
Old 11-07-2010, 03:35 AM   #32
Number21
Number21's Avatar
Yeah, the heaviest wall you can afford is definately recommended. Even if you used type M (the thinnest) it wouldn't be nearly as dangerous as PVC, just prone to pinhole leaks.
Number21 is offline
Old 11-09-2010, 09:27 PM   #33
aggie91
I'm just glad to be here!
aggie91's Avatar
Why not use one of the new piping methods that use aluminum pipe such as:
http://www.garage-pak.com/compressed...ipe/index.html
or
http://us.kaeser.com/Products_and_So...iping/pipe.asp
or
http://www.transairaluminumpipe.com/...ir-piping.html
another
http://www.rapidairproducts.com/
there are others, even one that has cast aluminum fittings, i just can't find it right now.
At work, we have used mostly threaded black pipe and some extruded aluminum pipe from IR for our new compressor installation. That was for the 4" diameter main header...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 11-13-2010, 06:01 PM   #34
piro222
Wow! Glad I read this thread!!! Was planning on plumbing my airlines with PVC. Clear to me that I definitely don't want to do this!!! Even a busted rubber airline with a metal fitting on the end bouncing around the shop like an angry rattlesnake is no fun either, but never have been bitten yet!!!
BHSM Certified [Bigger Hammer School of Mechanics]
Ten trips to the parts store and I can fix anything!
66 Suburban; 63 Fleetside
71 C10; 72 C20 Camper Special
62 Dodge Town Wagon
98 C1500 Silverado; 99 K1500 Suburban
piro222 is offline
Old 11-17-2010, 03:28 PM   #35
aggie91
aggie91's Avatar
here is the link for the pipe with metal fittings:
http://www.pattonsinc.com/piping/piping.html
All you need to install this stuff is a tubing cutter and a deburr tool. The fittings are push to connect.
Karl
The LST Challenge:
aggie91 is offline
Old 11-17-2010, 10:03 PM   #36
Number21
Number21's Avatar
That looks pretty spendy. Copper can be joined with "sharkbite" fittings, which simply push together like that. Plus you can find that stuff at the local hardware store...
Number21 is offline
Old 11-17-2010, 11:12 PM   #37
Shane
Shane's Avatar
it not only looks spendy, it IS spendy ... I got a quote/price list a few weeks back from GaragePak and I was gonna have MORE in the air lines than in a compressor.
Nice stuff, but wheew-wee type L copper lookin' better and better.
Shane is offline
Old 11-18-2010, 12:39 AM   #38
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can use nylon DOT air line @ 75 cents a foot, 40 - 200 degress range and 150 psi working pressure. Connect it with push-ons made of acetal plastic. Rated at 250 -300 working pressure and -20 to +180 degrees. Its fairly cheap to do a whole garage.
dwcsr is offline
Old 11-18-2010, 01:19 AM   #39
newbraunie
newbraunie's Avatar
Piping compressed air through PVC is about the same as crawling under the truck with only the jack holding and no jack stands. Yeah the jack will probabaly hold but the one time it doesn't watch out.
1971 C20 LWB Cheyenne 396/TH400
2017 Chevy SS - Holden conversion
2015 Chevy SS
2013 Acura MDX
newbraunie is offline
Old 11-19-2010, 12:50 PM   #40
aggie91
aggie91's Avatar
Have you seen the price of copper lately?
Karl
The LST Challenge:
aggie91 is offline
Old 11-19-2010, 01:18 PM   #41
Shane
Shane's Avatar
copper is a drop in the bucket compared to that stuff. seriously.
Shane is offline
Old 11-19-2010, 07:15 PM   #42
Number21
Number21's Avatar
Yeah, 1/2" tube is about $1/1.50/foot depending on what thickness you buy. That's not really much more than the same size rubber hose from some brands. An air compressor worth installing permanent plumbing for costs at least $500+.
Number21 is offline
Old 11-19-2010, 07:41 PM   #43
msgross
msgross's Avatar
I'm super cheap so I went to harbor Freight and bought 100ft of their goodyear rubber air hose. No explosions and it covers my 2 car garage and the driveway...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline
Closed Thread
