Old 11-05-2010, 01:43 PM   #26
fixit-p
fixit-p's Avatar
Re: Why a 2 piece driveshaft?
Originally Posted by LennyGB53 View Post
Mine is a short bed flare side with a 2 piece shaft. I had a 1976 Ford with a 8 foot bed and it had a one piece shaft. The length thing makes no sense. All of the older cars that were huge had one piece shafts with or without coil springs. Think of the old Buicks, Olds and Packards. My shaft is fine. I'm changed transmissions and now I'm replacing the u joints and center bearing. My last truck was a '68 long bed and sent from a 3 speed manual to a TH350 and we kept the same driveshaft.
Here's a better explanation >>>> http://www.engineersedge.com/bearing...ing-bodies.htm
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 11-05-2010, 02:25 PM   #27
Keith Seymore
Keith Seymore's Avatar
Originally Posted by fixit-p View Post
That's what I said - "...it'll swing like a jump rope".
Makes me think of a joke: this engineer takes his tire into the Goodyear store to get it balanced. While he's watching the work get done (...because we always have to watch to make sure it's done right -lol) the young tire tech takes the weight displayed and splits it in two, putting half on the outboard face of the rim and the other half on the inboard face of the rim.
He asks the engineer: "do you know why I did that?"
The engineer clears his throat and says, "why, yes, in fact I do. If you were to put all the weight on one side, the offset of the wheel introduces a moment, the resulting force being proportional to the lateral distance of the offset and increasing with vehicle speed. The resulting magnitude can create a disturbance which can magnify, particularly at it's resonant frequency and be felt in the car at certain speeds, generating customer pleasability issues, erratic tire wear and/or durability concerns".
The kid looks blankly at the engineer and says "yeah. Cause if I don't it'll wobble".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-05-2010, 03:21 PM   #28
Dano69c10
Dano69c10's Avatar
I had always thougth it was also a clearance issue. The 2-pc has the primary shaft level to the chassis and the secondary tilts downward to the rear axle. This set up would have more clearance than a 1-pc shaft that tilts downward from the tranny to the rear axle. If the wheelbase is small enough the difference in clearance is negligible, but as the wheel base increases it becomes a ground clearance issue with the driveshaft. Aside from what has been mentioned in previous posts. I could be wrong, it wouldn't be the first time.
Just my $0.02
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 11-05-2010, 07:19 PM   #29
Kidd-7
Kidd-7's Avatar
I had my carrier bearing tear off the frame a few years ago; broke a u-joint & dropped the driveshaft. Had to have new "ears" welded on and a carrier bearing pressed on. Here is the shop that did it: http://www.samwinermotors.com/ excellent shop and very reasonable.
Kidd-7 is offline   Reply With Quote
Old 11-06-2010, 12:39 AM   #30
mr.chevy
mr.chevy's Avatar
Originally Posted by Keith Seymore View Post
The "critical speed" post is correct.
What you guys might be missing is that propshaft critical speed not just based on wheelbase but is also based on trans type (length), rear axle ratio, tire size, and engine type (larger engines allowing a higher top speed).
So - a long wheelbase truck with a low (numerical) rear axle ratio spins the shaft slower and might get a one piece, but an otherwise comparable truck with a high rear axle ratio might get a two piece.
K
I may be understanding you wrong but,
That doesn't make any sense to me. If i have the same trans as you but i have 5.14's in the rear the drive shaft spins a lot faster than it would at as say a 2.73 ratio. I had a 3/4 ton 67 with 5.14 posi in rear and it had two pieces. It has to turn 5 times around before the tires turns around once. hence the high rpm at a low speed.
Larger engines don't have anything to do with top speed. unless you need tons of power to get to a ridiculous speed. your last gear in your trans is 1:1 unless its an overdrive. Gears in the differential more than anything allow for a higher top speed.
Also i was under the impression that it was the short beds that got the one piece. i could be wrong.
Ben
Its a 67 Chevy C10 now, and its short now too.
Here is my 1967 Chevy C10 Shortened Build Blog
http://boyescustoms.blogspot.com
Here is my 1967 Chevy C10 Shortened Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=433535
mr.chevy is offline   Reply With Quote
Old 11-06-2010, 12:59 AM   #31
LennyGB53
That makes some sense finally raycow. Thanks...
LennyGB53 is offline   Reply With Quote
Old 11-06-2010, 01:05 AM   #32
LennyGB53
Stitch, many cars pulled camping trailers etc. that exceeded 1000 pounds. They put on Reese hitches and overload springs often to pull their camping trailers.
Old 11-06-2010, 02:59 AM   #33
fixit-p
fixit-p's Avatar
There you go right there, if an engineer were to do his critical speed calculations based on a vehicle speed of 60mph that 5.14 ratio may spin a 1 piece driveline at or near its critical speed, that same 1 piece driveline on the 2.73 ratio rear end @ 60 mph maybe well below its critical speed. Based on that logic the dive line on the 5.14 ratio rear end should be a 2 piece, larger diameter or different material.
Often times vehicles with smaller lower torque/hp engines were equip with lower gear ratios to compensate for the lack of power.
Old 11-06-2010, 03:02 AM   #34
stich626
yes I know that, but the truck was engineered to do it..
at ride height or bumber drag'n.
tail drag'n a wagon and tow'n kills ujoints,, and gives a stock 1 piece tube a slight twist to it..
draw a line on a driveshaft in a wagon then tow 1500 miles and look at the line again.. unless you drove like a granma, it's got a slight twist to it..
even light power over wet r/r tracks will do it..
once it starts it only gets worse..
stich626 is offline   Reply With Quote
Old 11-06-2010, 11:00 AM   #35
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
This thread has been long over due, and I appreciate such an excellent explanation to why some have different setups.
Sounds like the 2 piece is the better all around choice, as the 1 piece were used on trucks with lower gearing (Probably because it was cost effective).
2 piece was used for trucks that had higher gearing to keep critical mass down.
Do I have this correct?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-06-2010, 11:02 AM   #36
Roman
Are you serious? I am turning mine into a short bed and I need a drive shaft. Does that mean it will bolt on for an automatic or manual tranny?
And what is the length of it? do you know it off hand?
Mr. Chevy (or anyone), let me know what you find out. I'm in the same predicament. I just converted my long bed coild spring chasis C-10 to a short bed. I'm planing to keep everything else original 250 6 Cyl, 3 manual trans. But I need to resolve the driveshaft issue. My plan was to look in a bone yard for a one-piece driveshaft from a 67-72 6cyl, three on the tree tranny. Any suggestions? My other option was to have one custom built...suggestions?
Roman is offline   Reply With Quote
Old 11-07-2010, 12:05 AM   #37
WIDESIDE72
WIDESIDE72's Avatar
One piece ds' are always a larger diameter to compensate.
I have a 72 SWB step. I swapped in a 700r4. I slipped an old yoke I had into the trans, measured from where the middle of the front yoke would be to the where the middle of the rear yoke would be and got 55 1/2" at ride height. A few weeks back, I came across a Craigslist ad from someone selling a driveshaft out of an 85 Chevy SWB... It was 55 1/2" center to center as well.
WIDESIDE72 is offline   Reply With Quote
Old 11-07-2010, 09:27 AM   #38
Kidd-7
Kidd-7's Avatar
Sorry to high jack the thread here, but I'm curious; How did you convert from long bed to short? New frame or cut the old one? Also, do you know the length difference between the frames?
Old 11-07-2010, 11:48 AM   #39
franks72
Junior Member
franks72's Avatar
I've allways wondered why people want to go with one peice shafts. I have had 5 of these trucks over the years and only had one carrier bearing go bad. There plenty strong .My truck now has the stock two-peice and I run this truck at the track. 4500lbs, 180 shot of nos and no problems. I just dont see the advantages of a one-peice. my .02 .
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 11-07-2010, 11:54 AM   #40
WIDESIDE72
WIDESIDE72's Avatar
Personally, I am only going to a one piece because of a trans swap and the one piece was $35
Old 11-07-2010, 12:11 PM   #41
franks72
Junior Member
franks72's Avatar
Well I have to say I didn't think about cost on a swap, 35 bucks is hard to beat.
Old 11-07-2010, 01:10 PM   #42
raycow
Two-piece is fine as long as the truck is COMPLETELY stock. Once you start with modifications it is difficult to set up all 3 U-joint angles so you don't get vibration. Modifications can include engine, transmission or rear end swap, raising or lowering. This problem is legendary on 58-64 Chev full-size passenger cars that have been modified. A few of those have been converted to one-piece for this reason, and it's not an easy conversion on this car.
With a one-piece it's easy - just set the rear end angle so the pinion shaft is parallel to the transmission output shaft and you are done.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-07-2010, 04:11 PM   #43
mr.chevy
mr.chevy's Avatar
I had a c10 long bed frame that i cut down and welded back together and i am in the process of getting my bed off my truck to cut it down. I have a blog that has some pictures of what i have done so far. I should have a link at the bottom of this post. I can tell you specifics if you pm me and get my email.
Glad to help.
Ben
Old 11-08-2010, 10:15 PM   #44
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by dan42 View Post
They all came from the factory with a two piece driveshaft, long bed or short bed. If they have a one piece driveshaft, it's been converted.
They didn't all come with 2 piece shaft. I've got a 69 Chevy shortbed with coil and single piece. Never been converted. I also have a 68 GMC shortbed with springs single shaft. Also never been converted.
68gmsee is offline   Reply With Quote
Old 11-08-2010, 10:27 PM   #45
Justin87
Justin87's Avatar
My 95 V6 Camaro HAD a two piece drive shaft. Found out nobody but GM carried it and the price tag was $900 so I bought a one piece and have had no problems.
2006 Silverado 2500 HD
Justin87 is offline   Reply With Quote
Old 11-14-2010, 04:00 PM   #46
Sport/Truck
Sierra Grande Club
Were they manual transmissions by chance?
Old 11-14-2010, 04:09 PM   #47
63chevyll
gets board easy.......
63chevyll's Avatar
i always throught it was due to the trailing arm as the pivot and the 2nd u joint being in the same area...
Well i was wrong, but havent had any issues with my 2 piece shafts and even when hard racing no issues
63chevyll is offline   Reply With Quote
Old 11-23-2010, 09:30 PM   #48
67gmcstepside
Not to highjack this thread but I just got my 2 piece back from Mr. Driveshaft (3/4 to 1/2 ton conversion) and it seems my second shaft might have been made to short. How much of the front drv shaft spline is showing in front to the rear drv shafts yoke. Mine is 1.25 inches. Seems too much???
67gmcstepside is offline   Reply With Quote
Old 11-23-2010, 09:57 PM   #49
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have never ever, seen a stock 67-72 chevy truck with a factory one piece shaft...I have own many of these trucks, only two pieces.....
Maybe I am due, if they were available.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-18-2012, 11:06 AM   #50
projectx
I know this is an old thread but I'm thinking about installing a single shaft in my truck.
Has anyone had any issues installing a single driveshaft in their lowered truck?
Any suggestions on what shaft to use?
projectx is offline   Reply With Quote
