Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-16-2013, 09:57 PM   #26
docrock
docrock's Avatar
Re: My 42 Project
Back window is in
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 01-16-2013, 11:11 PM   #27
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: My 42 Project
window looks great.what company did you use for the seal?are you not going to use the outer trim ring?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-17-2013, 01:04 AM   #28
old yelr
Re: My 42 Project
Hey Chizzler, they only had the outer trim ring till 1941 after that they changed the way the window was mounted.
old yelr is offline   Reply With Quote
Old 01-17-2013, 02:01 AM   #29
docrock
docrock's Avatar
Re: My 42 Project
Thanks. The seal is from Filling Station. I use them because they are real accurate and fit great. I didn't have the die cast trim so I had the glass company make it in the 46 style. I guess the glass is different for the trim. I like the look of the die cast but in 42 they had gotten rid of all the chrome. My headlight rings are painted brass. Not sure what I am going to do with those
Old 01-17-2013, 09:36 PM   #30
docrock
docrock's Avatar
Re: My 42 Project
I am working on my side windows today. I had the glass made to fit without the metal frames. I am using stock regulators and am not sure what to do about how to attach the glass to the regulator. I installed the bottom track of the metal frame window to the all glass window and it is twisting and binding. Any ideas about a bottom track or do I need to make something?
Old 01-18-2013, 08:06 PM   #31
docrock
docrock's Avatar
Re: My 42 Project
got it figured out. I am using 51 to 54 glass channel. It is the same size and it holds the window better. I will post pics when I get them.
Old 01-26-2013, 04:22 PM   #32
docrock
docrock's Avatar
Re: My 42 Project
Got the dash trim on
Old 02-21-2013, 10:01 PM   #33
docrock
docrock's Avatar
Re: My 42 Project
Posted via Mobile Devicegot the new window tracks in. Work perfect
Old 03-03-2013, 04:30 PM   #34
docrock
docrock's Avatar
Re: My 42 Project
I have been trying to get the windshield frame apart for the new glass and just doesn't want to come apart. All the screws have been removed and I have been soaking it in PBR but it is just stuck any ideas?
Old 03-03-2013, 05:01 PM   #35
CHIZZLER
CHIZZLER's Avatar
Re: My 42 Project
mine was the same way.you can try to put one end on the floor under your foot and try to wiggle it back and fourth.or try the same method and pop the corners up with a rubber mallet.depending on if your going to re-use the glass you could break the glass out which might take some tension of the connecting bars.good luck.
61-crew cab D-max
Old 10-19-2013, 09:24 PM   #36
docrock
docrock's Avatar
Re: My 42 Project
Size:  67.0 KBi decided to go 3/4 ton 1970 frame. Somebody gave me the frame. I will get to use my factory flatbed and it's cheap to buy parts for. Small block with a 350 and headers. Lokar shifter late model column. Two universals for power steering. Big brakes and easy no haste driving anywhere I want to go.
Old 10-19-2013, 09:36 PM   #37
docrock
docrock's Avatar
Re: My 42 Project
Size:  58.0 KBwheels stick out about 1 inch but these are wide wheels. I am using dually wheels which should be under about 2 inches
Old 01-01-2014, 08:34 PM   #38
docrock
docrock's Avatar
Re: My 42 Project
Got the windshield together. Wow that was a pain. Name:  image.jpg
Old 01-20-2014, 08:09 AM   #39
solidaxel
solidaxel's Avatar
Re: My 42 Project
Did you find a transmission?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-20-2014, 01:31 PM   #40
docrock
docrock's Avatar
Re: My 42 Project
Yes I have two
Old 01-25-2014, 02:56 PM   #41
swamp rat
swamp rat's Avatar
Re: My 42 Project
Subscribed! Keep up the great work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-25-2014, 10:03 PM   #42
docrock
docrock's Avatar
Re: My 42 Project
The motor is at the machine shop and is going to be ready next week. Should go in on Saturday. Then I can make final adjustments to the cab. Also scored a rebuilt 700r4 for it and with a lokar shifter in the almost stock position, that will look cool. Pics next week. Thanks for subscribing
Old 03-04-2015, 05:26 PM   #43
docrock
docrock's Avatar
Re: My 42 Project
wow its been a year since I posted. Not much on this truck going on but I did build a motor for it so its coming soon
Old 03-05-2015, 04:57 PM   #44
NEWFISHER
NEWFISHER's Avatar
Re: My 42 Project
Looking good! I like the color and seat combo
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 06-13-2015, 06:09 PM   #45
docrock
docrock's Avatar
Re: My 42 Project
Back at itName:  116.jpg
now its in the garage with its bro truck
Old 06-13-2015, 06:10 PM   #46
docrock
docrock's Avatar
Re: My 42 Project
Old 06-13-2015, 06:14 PM   #47
docrock
docrock's Avatar
Re: My 42 Project
Got the motor in and am changing the interior to the original from the other truck. Matches the seatName:  125.jpg
Old 06-23-2015, 11:12 AM   #48
solidaxel
solidaxel's Avatar
Re: My 42 Project
Edited by Forum Staff
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
LS 3 4L70E
Old 03-24-2016, 08:20 PM   #49
docrock
docrock's Avatar
Re: My 42 Project
sorry it took so long to get back to this. I have seen that piece on ebay.
Sold the 54. The woodie is done so its time to get back to this
Old 07-19-2016, 03:43 PM   #50
docrock
docrock's Avatar
Re: My 42 Project
so its been a while. Changed the idea back to the original direction. Built a gantry and moved the body back to the original chassis. Installed the new sbc and 700r4, ended up rebuilding it also. Used mounts for 47-53. the worked great just had to cut them to fit. Installed a 55 car rear end. Rebuilt it with 308 gears new bearings and brakes. Looking for a radiator that will fit with the radiator support brackets. I installed corvette cast iron exhaust manifolds and they are clearing the steering box so that is cool. I guy gave me some original 46 bed sides so I am on the hunt for steel rear fenders.
