Old 02-20-2011, 12:01 PM   #26
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Recommend a trans...
Being DBW, you're going to be limited to 4l60e, 4l80e or maybe TH400 with the kick down switch mounted on the gas pedal. Everything else requires a kick down cable or TV cable which you would need to convert to a DBC throttle body to use. Or maybe even power glide, no experience there.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-20-2011, 01:36 PM   #27
72gmcshorty
72gmcshorty's Avatar
i guess a trans from a 2005 6cyl trailblazer is also no good?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-20-2011, 08:23 PM   #28
clinebarger
It will not bolt up. The bellhousing is way different.
clinebarger is offline   Reply With Quote
Old 02-23-2011, 11:13 PM   #29
72gmcshorty
might be lucky...the guy i bought the motor from got in touch with me. He has a 4l60e (2wd) and a 4l80 (4wd) for $500 (for both)....crossing my fingers...
1992 Gmc 2wd
Old 02-24-2011, 12:00 AM   #30
Critter
Future TOTM Winner
Critter's Avatar
...a 4l60e (2wd) and a 4l80 (4wd) for $500 (for both)....crossing my fingers...
A usable 4x4 4l80e is worth $500 by itself. Are they both from an LS engine or an older model?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-24-2011, 09:12 PM   #31
72gmcshorty
both from ls. the 4l60 (2006) and the 4l80 (2002).
1992 Gmc 2wd
Old 02-24-2011, 09:49 PM   #32
usmcchevy
usmcchevy's Avatar
Get both, use the one you want and sell the other.
Build thread
LSx Swap FAQ index
